Question about Dell Dimension 2400 PC Desktop
Windows Update - Monitor failure
I just uploaded the latest Windows Update on an old Dell Computer and after restarting, the monitor won't work. I've tried another monitor and nothing. Any ideas?
  • 63 Answers
It must be a virus or your monitor has blown up.
I hadthe exact same problem once we had to thro it away!
Posted on Jan 30, 2008
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
When my Dell Ustrasharp goes into energey saving mode, it won't come out of it. Otherwise, the monitor works fine. Anyone experienced the same problem?
Sometimes it is not the monitor itself, the monitor gets the signal from your pc, what U could do is to upgrade your video driver to the latest version, try factory reset your monitor if the firmware was not providing a solution
Jun 16, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
15" Dell monitor is blank-connected
there can be many issues why there is no screen on this other computer.
1. video card failure
2. No system boot "bios issues"
3. Cables not connected correctly
4. Bent pins
First you want to do some trouble shooting. If this monitor works with a computer and not working with another then obviously there are some issue with the computer itself.
Have you check the resolution that Windows is putting out?
Try booting in SAFE mode this will set the computer's resolutions to the lowest so you can see a image. Most monitors in this caliber cannot handle certain high resolution signals.
We are here to help please update us with any more information you may have such as:
Are you see-ing any boot up screens?
Do you hear the system actually boot?
Thanks for using Fixya.com I do hope this was very helpful information for you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 30, 2010 | Dell E153FP 15" LCD Monitor
My computer froze while I was transfering files and when I restarted it my display shrunk and I can't get it to stretch to fit the screen. I tried using the buttons on the monitor but it says that it is...
In such cases the buttons do not work. Go to start->Control Panel->Display->Settings->Advanced->Monitor->Properties->Drivers. Here you will find an option of Uninstall drivers. Select it. and close all windows. Reboot the PC. Start->Control Panel->System->Hardware->Device Manager->Action->Scan for New HW. Windows will scan for new display and load its drivers. Your display would be alright.
Dec 04, 2009 | Hansol Computers & Internet
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Will not print from computer
Hi mflanagan98,
you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
NOTE: DON'T PERFORM THESE STEPS IF YOU HAVE ANOTHER PRINTER INSTALLED ON THE COMPUTER. JUST RESTART THE COMPUTER.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just update me if the issue is resolved or not.
Oct 19, 2009 | Dell 968 All-In-One Printer
Printer aio 926 communication error
hi aweintra,
you can do the following steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
just send me an update if the issue won't be fixed. have a great day.
Oct 18, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Dell Dimension 2400 PC Desktop Logo
23 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
