Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Connector hose we tried to adapt the dishwasher hose so that instead of hooking it up to faucet, it connects to the the undersink water pipe, using tubing and clamps and a shut off valve. we can't get it to stop leaking where the clamp is. Are there adapter kits avail to do this? This way we wouldnt have to keep taking the hose on and off from the faucet.
  • Anonymous Mar 24, 2014
    How do you replace the plastic hose connector on the supply hose
The water pressure is too high in the intake for your kit. use a higher grade kit or reduce the pressure .
Posted on Jun 08, 2008
Kitchen faucet quick connect adaptor like portable dishwasher, read on
You can't find a portable dishwasher connector? Try an appliance parts supplier.
May 17, 2014 | Plumb Pak Faucet Adapter
GE portable dishwasher connector hose slips off faucet adapter
Google your dishwasher you will see parts on line There are loads just looked .
Apr 13, 2017 | Dishwashers
Copper piping? Tub faucets
1. Measure piping size with tape measure or read printed on pipe. 2. Visit local hardware store and take the faucet. 3. Tell them you need a tubing cutter and sharkbite adapters for the faucet you have. 4. Cut pipe with tubing cutters. 5. Push on sharkbite fittings. 6. Install faucet and supply hoses. 7. Take Bath.
Apr 28, 2013 | Plumbing
Whirlpool gold drains all the time, unable to fill
Hello
Ensure the water faucet is turned on and the connection between the water and the dishwasher is secure. The hose connector should be snapped into place between the water faucet and the water hose.
Straighten the water hose and check for possible obstructions in the water hose, the water faucet and the hose connector. Clean as necessary. Turn on the faucet hot water slowly until it is all the way on to ensure proper water flow to the dishwasher.
Open and close the dishwasher door firmly. The dishwasher will not start a wash cycle if the door is ajar. Verify that the dishwasher is plugged in to a working power supply and that a wash cycle has been selected.
Avoid running other appliances that use water, such as a clothes washer, while the dishwasher is running, to avoid improper water pressure. This may result in a lack of water flow to the dishwasher.
Check to make sure large dishes, such as cookie sheets, pots or pans, are not blocking the spray jets. Avoid overloading the dishwasher.
Sep 28, 2011 | Dishwashers
On my wslp1100 model its very very hard to connect the hose to the faucet adapter, it just does not want to go in ,also it leak's a lot of water from where the hose connects to adapter , I have to wrap a...
Hi... I had the same problem. Instead of trying to figure out the faucet/adapter issue (was too pissed off) :) I took my old washer hose and just used that. Connect the washer hose to your sink and the washer just like it would be if you used that adapter hose. You will want to make sure it is tighten good or it will leak a little...and make sure that the adapter hose end is in your sink because that is where the used water empties out from.
Hope this helps.
Aug 06, 2010 | GE Spacemaker WSLP1100D Top Load Washer
My hose on my ge portable dishwasher will not stay on faucet
do you have the right connector on the faucet, it should be like a quick connect that pushes on and then locks in place the red button is probly the release button, you have to find the right adapter for the faucet
Jun 04, 2009 | Dishwashers
Re dishwasher unit / sgs46m78au. water pipe/hose/ connections
The water connection is the smaller of the two and generally near the front of the machine, usually a threaded fitting on a electric solenoid will need a pipe to compression 90 fitting if its not already installed, it needs to be hooked to the hot water and that can be found on the left side going up to the sink faucet to be sure run some hot water and the side that gets warm is the correct one, you will need to turn off the water and install a T to connect the dishwasher if an unused shut off is not already there for the dishwasher. The drain line takes a hose and clamp and will hook into your drain iether through a dishwaser t or the disposal if you have one has a connection for it.
Dec 17, 2008 | Bosch SHU3305 Dishwasher
Danby portable dishwasher 1805W hose too short. Where I can find a extension hose.
First cut the hoses off near where they would connect to the plastic quick adapter. Leave a little slack at 2-3 inches between where you cut and the metal clamp.
Take those two pieces you just cut off to home depot or lowes. Afterwards you can chuck them if you don't want them (I did read below). Take the metal faucet adapter with you too.
For the water supply hose (this is the smaller one) need a Hose barb adapter 3/8 Barb x 3/8 FIP
You need a clamp for this.
Get a plastic hose the length you want and the right barb to fit the drain hose and your new hose. You need two clamps. Also you might consider hooking it up to an external water pump depending on your situation. If the hose is long or has to go up above 36 inches then you may need a pump.
Then you want a standard dishwasher connecting kit. They have them from 4-6 feet, they come with a 3/8 brass fitting make sure you get that.
You also need plumbing teflon.
I also wanted to replace the faucet connector because the plastic one it came with leaked all over the place. I got a quick snap that goes to a garden hose. It fits the metal faucet adapter that came with the dishwasher. . I had to get a few connectors to go from the garden hose adapter to the standard dishwasher hose.
Installation. Take the clamp for the supply hose and put it on the hose connected to the dishwasher. Put insert the barb and tighten the clamp.
Put teflon on the 3/8 male connector that came with your standard dishwasher kit. Connect it to the Barb adapter you just installed. Connect your standard dishwasher hose.
Connect the other end. Its pretty straight forward just don't forget to put teflon on any of the thick threads.
From this you can pretty much figure out the rest with the drain hose.
If I were to do it again I probably wouldn't have used the standard dishwasher kit. I would have gotten a cheap plastic tube and connected it. Also if you're happy with the plastic adapter they gave you save the plastic connectors you cut off and you can use another 3/8 barb adapter to connect it to the other end of your extension hose either a simple plastic tube or the standard dishwasher connector.
Dec 04, 2008 | Dishwashers
How to hook up portable dishwasher.. we have the dishwasher from a friend and the adapter, but i don't know anything else. do we turn the faucet on or just press start on the washer???
Hi. Thanks For The Question. The Adapter Goes On THe Faucet .It Screws On. Then The HoSE From The DishWasher Hooks On To The Adapter Turn On The Water. Plug DishWasher In To The Wall Socket Put Dishes In Lock The Door Push Cycle Good To GOo. Thanks The Appliance Doc
Oct 03, 2008 | Dishwashers
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
277 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
