Question about Mitsubishi HS-U560 VHS VCR
VCR started eating tapes.
I have a Mitsubishi HS-U560. It's kind of old, but it has worked like a champ and I've never had ANY problem with it until now.
When I insert a tape the mechanism feeds the tape around all the capstans, but the Take-up reel doesn't pull in the slack. (I can see this because I took off the top cover to watch it while the tape loads.) When I hit play, the extra tape near the between the read head and the cassette begins to grow. Also, neither rewind nor fwd work.
Any hints? Is a motor out, or a gear out of alignment?
Thanks,
--Buddy
  • 1 more comment
  • schalley Jan 30, 2008
    Addendum:
    Still have no solution. Does anyone know a trick to getting the mechanism to "think" there is a tape inserted so that I can observe whether the main REW and FWD spindles are being engaged?
    Thanks!
    Hi Jim,
    Thank you VERY much for taking the time to offer your suggestions to try!! I'll try the easy one first (#1 solution), though even the cleaning tape hangs up the same way.
    There doesn't seem to be any torque getting to the sending and pick up spindles. So I suspect a problem with either the drive mechanism between the motor and the send/pick-up spindlesl; or maybe event he motor itself.
    I'm pretty good at taking things apart and utting them together again... (though I usually find the "trick" to taking something apart as I go). From what I have seen in this VCR, Mitsubishi did a pretty good job of making assembly/disassembly fairly simple... but I haven't tried taking the whole mechanical assembly apart yet! Any idea where I might be able to get a service manual fort his machine? (Mits. HS_U560).
    Thanks again!
    --Buddy
  • rachandy Aug 13, 2008
    Wondering if a cause was found for this problem. I have the same exact thing. Seems all works except the tape spindles not turning. I am down under the bottom cover now and still cannot see what drives those spindles. There is a white pulley about 2 1/4 in. dia. under the center of the spindles but has no belt. There is a black tar like substance in the pulley groove?
  • 2,130 Answers
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
Yes - There are cassettes available that are made out of clear plastic that allow you see what's happening. You can also trick the player into thinking there is a tape. There are sensors (mechanical & infrared sensors) that you can bypass.
- Jim
Posted on Jan 30, 2008
Error code E4 on Mitsubishi HS-U576 VCR. Machine is eating tapes.
Hi, The error E4 means Reel Lock Detection.
Thanks! mannu_rakesh
Sep 02, 2009 | Mitsubishi HS-U576 VCR
VCR will not switch to program mode
Solved my problem by reading a previous post about taking apart the remote and cleaning the contacts. Believe it or not it the remote is working again.
May 14, 2009 | Mitsubishi HS-U545 VHS VCR
No manual or remote
Following the instructions I have been able to program a Philips SRU4105WM/17 universal remote using the first Mitsubishi code from the code list. However, I had to have the universal remote "learn" the vcr/tv button function (I assigned it to the Exit button). Good thing I still have the original Mitsubishi remote:-) I haven't tried having the universal remote learn all the functions, such as Cancel, Counter Reset, Audio Function, Video Function etc. I could see if I'm able to program those, if you'd like. LMK if you have any other questions.
Mar 30, 2009 | Mitsubishi HS-U560 VHS VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
Part for VCR mechanism
I'm not sure what part you ned, but parts are still available from generic suppliers although not from Mitsubishi. Where are you located?
Dan
Sep 27, 2008 | Mitsubishi HS-U560 VHS VCR
A tape is stuck in my VCR. and i cant get it out, How can I remove it? notheng
Open bottom metal cover. Rotate the belts of the motor. Cassete should unload from Spindle and reel back into the cassette. Then please open the VCR top, and you will see a belt and gearmechanism on the right side of the cassette compartment. Manually rotate the gears and the tape will slowly come out.
Jul 20, 2008 | Mitsubishi HS-U560 VHS VCR
Replacement Belts for Mitsubishi HS-U560
You can try Vancebaldwin.com or MCM electronics corps, or even tritronics INC.
Mar 22, 2008 | Mitsubishi HS-U560 VHS VCR
Bad recording from any source
The fact that both inputs give you a bad recording indicates its something common to both inputs. First thing I would do is try cleaning the heads. It's the cheapest solution to try. There is also an erase head as well, but that is usually not part of the video head. The erase head erases the tape just prior to the record head recording the new material on the tape. Problems in the erase head will cause you to see both what you just recorded and what was previously on the tape. The picture will be distorted and shifting back and forth between the new program and the previous one.
- Jim
Nov 29, 2007 | Mitsubishi HS-U560 VHS VCR
Televison & Video Logo
3,601 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
