Question about Canon CanoScan N650U Flatbed Scanner
My Canoscan N650U
My computer finds the new hardware, but I don't know what to do from there. I went and searched for the driver... installed it... unzipped it... but nothing happens. How do I access my scanner to put pictures on my computer?
Hope you can help...
Earthgal
    Genius:
  • 1,554 Answers
The driver only gives you the connectivity with the printer.
if you have Microsoft Office it will allow you some use of the scanner.
Open a blank document , select insert/ picture /from scanner.
scanner should activate.
if you want any better you will have to have a better publishing /scanner program.
Posted on Jan 30, 2008
Canoscan N650u driver
I have Windows 7 32bit running with the driver from canon XP Driver - CanoScanCSUv571a.exe.
1. Download driver from Canon
2. Extract driver to CanoScanCSUv571a folder
3. Click Start orb and Control panel
4. Make sure classic view if checked
5. Double click Device Manager
6. Under imaging devices right click CanoScan N650U/N656U and select update driver software...
7. Select Browse my computer for driver software and click browse button to location of the CanoScanCSUv571a folder and click on Next button.
8. Ignore any warnings the driver works fine. Have been using it for a long time now
This will only work with Windows 7 - 32bit OS. I personally reinstalled windows 7 - 32 bit. Had too many problems with the 64bit OS and all by Older software. Could not afford to buy all new hardware and software for use on a 64bit system.
Jan 10, 2014 | Canon CanoScan N650U Flatbed Scanner
Unable to install canoscan N650U on windows 7 TOSHIBA
I have many years repairing Canon scanners so here is my suggestion for you.
First I would google Canon CanoScan N650U drivers, it should pull up Canons website and take you directly to the newest drivers avalible they are free. Then I would disconnect your scanner from your computer and install the latest drivers. Also while your on Canon's website download capture perfect its free and it works with your scanner for scanning purposes. I would then install the drivers and then hook up the cable to your computer. At that point you should get a pop up saying new drivers are being installed. Once there installed reboot your computer and you should be ready to start scanning.
I hope this helps you out.
Mar 28, 2011 | Canon CanoScan N650U Flatbed Scanner
I have recently installed Windows 7 operating system and can not find a driver that is compatible with my old Canoscan N650U. Can you assist?
This will fix your problem, just be sure to follow the steps below.
Download the Windows XP Drivers HERE
  1. Install the drivers
  2. The driver didn't install, but unzipped to C:/Temp/CanoScanCSUv571a
  3. Go to C:/Temp/CanoScanCSUv571a and uncompress CanoScanCSUv571a.exe
  4. Plug in your scanner
  5. Type Device Manager into your search bar ( on the start menu )
  6. Run Device Manager
  7. Click on Add a Device and select the scanner
  8. Right click on the scanner to update driver information
  9. Select browse my computer for driver software
  10. Type in: C:\Temp\CanoScanCSUv571a
  11. Click next and it will install the drivers for the scanner
This worked for me at work, hope it works for you
Pleas Rate.
Mar 19, 2011 | Canon CanoScan N650U Flatbed Scanner
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
Install canoscan n650U with windows 7
sorry, none of the solutions listed above worked for Windows 7 on the N650U. will have to keep scanner on a stand alone computer with old Windows
Jan 19, 2010 | Canon CanoScan N650U Flatbed Scanner
Can't get drivers for CanoScan N650U scanner for Vista 64 bit. Anyone have a work-around?
This works for 32-bit, maybe try the same for 64 and see if it works?
1) Download the drivers for XP from Canon's website
2) Install the drivers.
3) They will install to C:/Temp/CanoScanCSUv571a, go there
4) There is a compressed file called: CanoScanCSUv571a.exe in the foler
5) Use 7-zip to uncompress the folder
6) Plug in your scanner
7) Go to your device manager under the Control Panel
8) Go to Imaging Devices and select your scanner
9) Right click to update driver information
10) Select browse my computer for driver software
11) Type in: C:\Temp\CanoScanCSUv571a
12) Click next and your scanner will work.
Jul 05, 2009 | Canon CanoScan N650U Flatbed Scanner
How do i install my N1220U on vista windows?
Ok, I think I managed to get my Canoscan N650U working with Vista using the XP drivers from the Canon website.
Download the drivers and extract all the files to a directory on your PC.
Connect the scanner, the popup will appear saying found new hardware, normally it wants the files from the CD, but there is an option to find the drivers at a particular location, choose that and point it to where you downloaded the XP Canoscan drivers. Let it install. You should then see it in control panel and can test it OK.
Jan 07, 2008 | Canon CanoScan N650U Flatbed Scanner
Canon n650u
Here is the download site for the drivers:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6858
Just choose your operating system, download, and install.
Be sure to disconnect the scanner BEFORE installing the driver.
Jan 06, 2008 | Canon CanoScan N650U Flatbed Scanner
Canon CanoScan N650U Flatbed Scanner Logo
66 people viewed this question
old marine
old marine
