Coleman direct vent forced air furnace
So It turns on for a few seconds and then turns off again. While its on, it blows warm air just fine and all that its just that it only stays on for 5 seconds at the most.
  • 2 more comments
  • Towel Jan 30, 2008
    please help I have kids and they are freezing
  • iworkalone Feb 20, 2008
    i have the exact same problem w/ a Coleman furnace in one of my rental units. turns on for a minute then turns off. The unit does NOT appear to have a thermo couple. it has electronic ignition. the diagnostic light is steady green indicating no failures. i read on another forum where someone troubleshot the circuit board to find a cold solder joint. it is NOT the thermostat as i have bypassed it completely & it still cycles. problem started a couple of days ago and all indications point to a thermocouple; on the cover plate it shows a 'thermal rod' (?). going by memory here so it might be called something else. haven't been able to locate one of these on parts suppliers for this furnace. can't afford to replace this thing. any help would be greatly appreciated.
    roberto
  • crlnfenton Dec 07, 2008
    I have replaced the fan switch and the thermostat and still it heats the house then shuts on and off every 5 seconds non stop
  • Anonymous Feb 15, 2009
    I have the Coleman EvCon furnace and my unit does the same thing. Everything starts up fine and then it shuts off 5 seconds later and continues to do so.  It will do so as long as the unit stays on. How do you recommend I fix the problem?
I am a furnace technician and to solve the problem.You will find on the opposite side of the ignitor their is a flame rod with a wire connected to it.Remove it and clean it with sandpaper and re install it and it should fix the problem.If this is dirty it won't sense ignition and the board thinks that is it introducing raw gas into furnace and it isn't igniting and shuts off as a safety precaution.If you see a blueish tinge on the flame rod you should probably replace it.
Posted on Aug 19, 2008
Check the flu. It has an outer pipe for fresh intake air and an inner pipe that allows the cumbusted air vent out. If the inner pipe is rusted through it sucks the combusted gas back into the fresh air side and flame dies off due to the lack of oxygen and shuts off the gas valve.
Posted on Jan 01, 2009
    Problem Solver:
  • 14 Answers
Gas direct vent units such as these (not sure what model you have) typically have a thermocouple, or if the thermostat is mounted away from the unit, a thermopile. Either of these could be defective or in some cases, the valve is bad. Make sure there is no obstruction at the vent outside as well, as this will cause the unit to shut off due to lack of combustion air.
Posted on Feb 04, 2008
My top elements stay a ornge glow on one side and black on the other side
Posted on Dec 13, 2008
  • rickycline63 Dec 13, 2008
    my top elementts stays a orenge glow on one side and on the other side stays black i would like to no what that means
I have a coleman 7956c856 direct vent forced air furnace it ignites fine but the blower wont kick on
main fan should come on once furnace has heated up to supply hot air to the house. make sure proper voltage going to the fan. fan relay in board may be shot
Jan 29, 2014 | Goodman GMS90703BXA Heater
Coleman Presidential Furnace 6806A842 heat switch pops then cool air
Make sure all vents are open and filters are clean. Likely an air flow issue but possibly, though unlikely, both switches are bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 05, 2017 | Heating & Cooling
Heat cycles off too often
Proper make & model of furnace please.
Jan 03, 2013 | Coleman Heating & Cooling
Coleman combustion air switch failed to close
Hi, new switch can be found on amazon... here: Amazon com Coleman air switch. I hope this was helpful. Cheers
Nov 24, 2010 | Coleman Propane Forced Air Heater...
Coleman gas furnace. Burner will re-fire for a few seconds during the cooldown. Model G8C07512MUB12A
This is a little complicated because it can be several things and you need to provide more specific info....It could be your furnace is shutting off on the High Limit...which means your furnace is running too hot...check the filter , return air vents etc would be an airflow problem...dirty blower....Furnace can be too big for your house....when the furnace shuts off on High LImit , the fan will continue to blow air , cooling it down as usual and once the furnace cools enough to reset the high limit trhe furnace will Ignite again as long as the thermostat is still calling for heat . The furnace could also be running too long and getting too hot....your Ductwork can be too small...many factors come into play
Oct 25, 2009 | Heating & Cooling
My Carrier 58WAV136 forced air heater's problem is as follows - Thermostat works fine, when desired temp is reached, the fan motor (blower) kicks on. Sometimes it stays blowing for a couple of seconds,...
There should be a code list inside the furnace panel access door. Find it and see what code 41 says, as I can't remember right off hand. Some of the possible causes could be air in gas line or low gas pressure. Could have blocked vent especialy if vented with plastic. Check for bird nest or dirt dobbers in vent. If vented with plastic could not have proper rise 1/4 per foot and have water trapped in pipe blocking vent. Is this a new problem or has this occured since installation?
Oct 07, 2009 | Carrier Heating & Cooling
Furnace clicks multipal times while running.Is this normal?
As it starts and stops several switches will open and/or close, sometimes you can hear them. When it's just running then it may make a few noises from expansion and/or contraction.
Mar 30, 2009 | Coleman Heating & Cooling
Short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Jan 21, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
2,595 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
