Question about Car Audio & Video
Need help on hooking up a xdvd700 dual without ebrake
Hi i need help on hooking up the xdvd700 dual so i can watch tv/dvds with out the brake all the time
  • cubbrockvi Mar 02, 2009
    i have a pyles five inch in dash dvd player it was working fines all of a sudden the displays stopped showing dvd plays but i cant see anything
I have the xdvd700 dual. my screen goes blank when it comes all the way up. is there a solution for that? or is that manufacture's problem?
Posted on Oct 03, 2008
When I do that, I have an electronic defect. The lock of my car has broken???
Posted on Apr 12, 2008
    Problem Solver:
  • 6 Answers
Simply hook up the parcking brake lead to a ground source, problem solved.
Posted on Feb 05, 2008
How do u unlock a dual xdvd700 radio to watch movies
you need a switch so you watch tv it only cost about $5.00 just hook it up to your yellow wire and ground it and your done
Oct 01, 2010 | Dual Electronics XDVD710 Car DVD Player
E-Brake Problem
you have connected it correctly, that is just how those units work. there is a pattern to the ebrake for it to view video.
1. start with the ebrake off and follow this pattern.
2. on for 2 secs, off for 2 secs, then back on
or you can just put a toggle switch instead of connecting it to the cars ebrake wire. wire as follows
1. use a 2 wire switch.
2. connect one wire of the switch to ground
3. connect the other one to the ebrake wire of your dual unit.
4. then you would do the same pattern with the switch as you would have with your ebrake. this will allow you to view while in motion without your ebrake engage
hope this helps
Aug 26, 2009 | Dual XDVD8181 Car Video Player
I want to watch dvds while driving gotta a dual xdvd700
my car radio is dual xdvd700 it wont show the image on dvd
Jun 16, 2009 | Dual Televison & Video
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Aug 26, 2008 | Dual XDVD8181 Car Video Player
Dual xdvd700 want play cds
I am having this exact same problem!!! Help!!
Jul 24, 2008 | Pioneer AVH-P5700DVD Car DVD Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
Just ground out the Ebrake wire... it will work fine then. Even if you just link the ground and ebrake wire together and ground them together it works!
Dec 01, 2007 | JVC KD-AVX33 Car Video Player
DUAL XDVD700 BYPASS
The way you bypass the E Brake is you have to ground the wire to the radio sleev itself. There are two different peices. The radio itself and the sleeve that holds the radio in place. Take the yellow wire (the ebrake wire, not the yellow ignition wire) and open the metal connector up just slightly. Attach that wire to the top of the sleeve on 1 of the teeth located near the front of the unit. You have to make sure that the connection is good or it will not ground. Next slide the clear plastic over the wire so the only connection is with the tooth.
Then Insert a cd or dvd in the player. Press play on the remote and then push stop 2 X times on the remote. After you have done that press 26604 on the remaote and then press enter. This will permanently unlock the parking brake feature and allow you to watch dvds while in motion. If you need any further help you can eamial me.
Nov 19, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
389 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
