Question about HP Pavilion a305w (DM181AR) PC Desktop
Bad picture when viewing videos on internet
The picture is distorted, and the video runs really slow, and choppy.I know it's not the media player because when I try and run a flash video, it runs just as bad. I've change the screen resolution, and just about any other setting I could think of. But nothing has really helped. I'm not sure if the product I chose is right. On the front of the tower it says HP Pavilion, and has 4530 on the bottom of the front.
I havet the same problem
Posted on Feb 04, 2008
    Scholar:
  • 80 Answers
Hi
you might try uninstalling and reinstalling the graphics drivers and then set the screen resolution according to the monitor size
Posted on Jan 30, 2008
  • 63 Answers
You obviously are low on memory, You will need to back up the stuff you want onto a cd and reset the computer
PS: If you have HP Demo games they willall be reset to 60 mins again
6ya staff
SOURCE:
Pc is choppy audio and video
Assuming that you are watching video in a web browser, there are several possibilities. A lot of video on the web uses Flash Player for rendering, so make sure you are using the latest version which fixes security issues and performance problems. You may also want to clear your Flash cache as well as your web browser's cache files, especially if you are seeing a lot of hard disk activity when this is happening. You may also want to consider cleaning out all of the Windows temp files and directories as well as defragmenting your hard disk.
On a low-bandwidth connection, you may also encounter issues related to buffering. If the player allows changing the size of the buffer, you may want to enlarge it. It will cause the media stream to pull more content before it tries to play it and when there is an interruption in the stream, it has more time to pull more data before the buffer completely empties.
You should also use Task Manager to see how much of your total RAM is being used and page file usage. If you are using a lot of RAM and the system is paging, it will slow down everything but the most obvious ends up being choppy or distorted multimedia playback. If either of these are the case, you may want to add more RAM or reduce the number of currently running processes. Background process can consume a lot of memory or CPU cycles that interfere with your foreground process.
Sep 28, 2014 | Microsoft Windows Vista Ultimate Edition
My laptop runs really slow & windows media player doesn't work properly
Hello.
We need more info before we can properly diagnose your Media Player issue. Is the content you are playing from the Internet or is it saved to the hard drive?
Please test Media Player by doing the following:
- Reboot the laptop
- find a local video file that is saved to your hard drive
- double click it and see if it plays correctly
If the file plays correctly then the issue was either the laptop needed to be rebooted OR the content that plays slowly is from the Internet and your Internet connection is not fast enough to play the video smoothly.
Nov 03, 2013 | google.com
Choppy internet connection
If you are a frequent viewer of Internet-based video, then you know how frustrating it can be when streaming video doesn't play correctly. When a video is described as being "choppy," it can mean several things, including out-of-sync audio, stuttering frame rate and/or inconsistent stream speeds. However, although this term can mean several things, there are several ways to address all of these issues at once and help make your video viewing experience a bit smoother. Empty your Internet browser's cache and temporary files. Click the "Tools" menu and then select "Clear Private Data Now" (in Firefox) or "Delete Browser history" (in Internet Explorer). When you browse the Internet, your browser collects information from the websites you visit and carries this information as temporary and cache files. Too many of these files can bog down your computer, so delete them. Disable hardware acceleration. Open your computer's "Control Panel" and then click "Display." Select the "Settings" tab, click on "Advanced" and then click "Troubleshoot." Drag the hardware acceleration slider all the way to the left. This procedure can help reduce the strain on your processor, which can lead to choppy videos. Add virtual memory. If you are using Windows Vista or 7, you can add extra RAM to your computer by plugging a USB mass storage device into the computer. The operating system will automatically convert the unused space into RAM. Run your disk defragmenting utility. Click "Start" and then select "Programs." Click "System Tools" and then "Disk Defragmenter." This utility will eliminate the fragmenting of files, which could be taxing your processor. Stop Slow Streaming Video http://www.delete-computer-history.com/slow-streaming-video.html
Feb 24, 2013 | Computers & Internet
Movies/videos are choppy and unwatchable... Only problem with pc.
Try lowering your screen resolution, and don't download / view videos in HD. Test with lower like 480 and maybe 720. Mine can't even handle 720 by the way.
Dec 01, 2012 | eMachines EL1360G-UW11P
The picture on my computer keeps freezing
I assume you mean video, pictures are stand still viewing anyway. There are a few reasons why this may be happening. 1. Low Bandwidth 2. Computer Overheated3. Graphics Card or memory lacking 4. Hard Disk May Be At Limit5. Cluttered Files "Defrag Needed"The Internet is a large part of video processing which can mean if the bandwidth is slow or is throttled which a lot of companies are doing these days. Throttling means slowing your bandwidth access down for two much usage even know companies will not tell you they are doing this it is the newest problem we are facing thanks to hackers who steal off the Internet for profit. Companies have banned together to stop this and regulated their customers so that everyone has equal share of the Internet. It is part of what several companies think is the solution and guess what the customer has to pay for it.
The best way to find out is to go and do a speed test to see if your company is giving you the promised bandwidth allocation. If they are not you may want to contact them or find a better service. This is affecting video viewing as well as browsing speeds. Click Here to test your speed.
Your computer may be getting overheated? Go ahead and open the case and take a peak inside it will not hurt you. Touch a piece of metal on the chassis before going into the box with your hand. Look at the CPU the thing with the fan on top of it. How does the fan look cluttered with dust? If this is the case you may want to clean the fan as well as the base below it these get packed with dust over time and cause blockage from air being able to flow down to cool the CPU. Packed dust is not only a fire hazard, I have seen many burnt up good expensive boards no good anymore because of dust buildup. Mainly in laptops this will cause parts that are soldered to become weak, they will eventually crack video card are really a problem especially with laptops if moved around while hot you could begin to start seeing things choppy on a screen.
Hard disc may be getting full as well check that by ticking My Computer then tick on your hard disc C:\ to see what is left on the drive. Clean out defrag unwanted software, files, things of this nature to clean the clutter. Your video card may need to be upgraded. Any video card these days that is below 128 is going to be slow running or choppy.
This is just a little information for you to look into if you keep these areas in check your computer will run good all the time and handle just about anything processed in today's computing world. A good software program for this "Free" is Ccleaner you can download it free at ccleaner.com....John
Apr 12, 2012 | Medion Computers & Internet
Purchased and installed LG GH22 Super Multi DVD Rewriter. It reads/burns data CDs perfectly and burn/plays back music CDs. However, video files come out with choppy picture and badly distorted audio. Have...
get the dvd rewriter to record at its slowest speed.you do this through the software,which im not familiar with sorry.also usr quality media eg verbartim or tdk
Mar 27, 2011 | LG Electronics 16x DVD and 48x CD-ROM...
When I play a movie the picture and sound gets "choppy" even with NEW dvds
You can try using another media player.If that does'nt work ,your DVD drive may be bad or need cleaning.Sometimes a bad ram chip can cause the video to mess up.Try playing a movie directly from your HDD downloaded from a website and see if its choppy if its not then its your DVD drive.If it is still choppy it could be the media player your using or it does'nt have enough ram memory/virtual memory.If you have XP change your virtual memory settings and the refresh rate in task manager.(Bring up task manager,go to view tab then update speed to HIGH).
Aug 11, 2009 | HP Pavilion zv6131us Notebook
PS3 Madden 09 runs slow in middle of game
You might wanna get disconnected from the internet in any way.
Go into the settings and network settings to get disconnected.How long do you play anyway?
Jan 17, 2009 | Sony Playstation 3 (PS3) Console
Trouble playing videos
well first of all i advise you to install windows xp on it because 98 is really passed out and wont function the way xp and vista do.
usually when playing a video or audio file and shows curruption this means the file formats ur playing are not supported on the aplication your using.
why dont you try to update your aplication ( windows media player, xing player or whatever ur using) or install a different one.
Apr 04, 2008 | Compaq Armada 1700 Notebook
Video in GoTo
This is actually quite common when using powerpoint files with online tools. From the guide:
"A current constraint of collaborative software (including
GoToMeeting) and the bandwidth connectivity to sites is that digital video-clips are NOT
transmitted satisfactorily. The sampling frame rate is not adequate for high quality motion.
To overcome this and provide the clips in their original quality to the virtual participants, the
transfer the powerpoint files and the associated video clips is undertaken as a routine
practice. They are then manually played at each site on adequate pausing and cueing from
you the speaker. It is advisable to confirm that they have viewed the clip before proceeding.
Given notorious incompatibility problems with wide variety of video standards, file formats,
proprietary codecs (for compression/decompression) and the main players (Windows Media,
QuickTime & Real), it is essential to have a technical pre-check of the clips completed in
advance at each site. This is scheduled for the inclusion in the technical testing on the
Wednesday immediately prior to your seminar.
NO audio track should be included with the video clips. This avoids the potential problems of
audioinstabilityor‘howl-around’totheconferenceandallowsyoutoprovidethesingle
commentary."
Sorry that formatting is a little sloppy. Hope this helps, and I'm not sure about the last part of what you said, in regard to media player being choppy. Were you saying that you played the source video locally in media player and it was choppy? Cause that would be another issue ;)
Feb 19, 2008 | Citrix GoToMeeting
HP Pavilion a305w (DM181AR) PC Desktop Logo
67 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
