Question about Brother XR-65t Mechanical Sewing Machine
Bobbin tangles up thread and jams machine
Hi there. Can anyone help me? The bobbin thread on my Brothers XR65 tangles up thread and becomes a knotted mess when I sew for a moment or two. Never happened in the past. What I am doing wrong? I am following manual instructions for loading bobbins. My machine is unusable because of this. Can anyone please tell me if I've lost a spindle or what? Thanks Johanna
  • 3 more comments
  • couldja31 Feb 08, 2008
    Well, thanks for trying to help, Katfou. It's the bottom thread that suddenly has one side of the bobbin threads in the bobbin get loose and then tangle in the upper thread. It only happens now when I backstitch. I was told by a salesgal recently that I need to remove the bobbin and then remove the metal plate beneath the bobbin, return it and then rethread. I'll let you know if that works. I've been too busy with my professional work to try but will do so tomorrow. If it works, I'll let you know. Thanks for your efforts. Johanna Sherman Texas
  • Anonymous Sep 13, 2008
    Recently my machine started jamming up in the bobbin area. The thread seems to "jump" out of the bobbin and get sucked into the sewing, causing a huge knot. Any idea of why? I've tried switching thread and rewinding the bobbin several times...
  • Anonymous May 20, 2009
    I have the exact same problem with this machine. Am very, very frustrated, because, as an experienced sewer, I've never NOT been able to fix a sewing machine problem before. I've tried all the suggestions so far including changing thread BUT, I actually don't remember if I tried my Gutterman thread when I did this. I'll try that next. I'm wondering, however, if something is loose in the machine....will look at this too.
  • Anonymous Mar 13, 2014
    bobbin thread not catching why cant anyone simply tell me how to set the timing
  • Anonymous Mar 16, 2014
    my thread is jamming from the bobbin brother vx 890
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Posted on Feb 08, 2008
This was happening to me too, I reversed the way the bobbin feeds and it has not tangled since then. I was orignally feeding the bobbin from the left side and now i feed the thread from the right. It works great this way.
Posted on Sep 23, 2008
  • Chance Miller Sep 25, 2014
    Yes! The bobbin needs to be reversed in the bobbin case. THere is a direction that the bobbin needs to spin when inserted into the bobbin case.
I am having a very similar problem, to tell you the truth, with the hours I've spent trying to figure out what is wrong, I'm tempted to hand sew! The top thread keeps wrapping itself around the bobbin or the bobbin chamber, then it tries to eat the material, then the thread either breaks or the needle won't move anymore. I have taken everything out and cleaned all of the parts. I have rethreaded the needle a million times, rethreaded the bobbin in both directions several times as well. I have adjusted my tension on both the bobbin and the needle. The only think I can think of now is a warped needle, so I guess that is my next project.....that and maybe the cheap thread thing could be an issue. I'm really at a loss after those two things are done. I guess it will be time to start doing it the old fashioned way. Women sewed by hand for hundreds of years, I guess it will just mean my projects will have some extra love in em....and a lot more time......I have an old singer by the way, so apparantly this happens with all models from what I can tell.
Posted on Oct 23, 2008
My top thread wraps around the bobbin, tangles and then the top thread breaks. An experienced seamstress told me to adjust the bobbing tension. I didn't even know there was a bobbin tension. I've been sewing for about 2 or 3 years, and this has never happened. I didn't even touch the bobbin tension, so I don't understand why I need to adjust it. She said the top and bottom tensions need to coordinate, like if one is loose, the other should match. Also, she asked if the needle was warped. Sometimes this throws the operation off. I hope this helps. If you have any other suggestions for me, please let me know via e-mail @ [email protected]
Posted on Mar 13, 2008
    New Friend:
My Brother XR-65 suddenly jammed up after I had been sewing all evening. I took it all apart, and cleaned it, to no avail. I never thought to re-thread the top thread - that fixed it.
I could not figure out what caused it to tangle like that, something must have slipped out of place at some point.
Posted on May 10, 2010
I had the same exact problem with my Viking and after trying everything to no avail I finally found out it was the cheap thread. I took out my meijer thread and put in Gutterman and it worked like it had never jammed before. DON'T USE CHEAP THREAD!! Hope that helps.
Posted on Aug 19, 2008
I am having the same issue all of a sudden when I changed out colors. I tried chaging tension and it doesn't change anything. I don't know!! Annoying
Posted on Aug 05, 2008
6ya staff
SOURCE:
Pfaff 1467 needle jammed in fabric and hand wheel stuck
Be sure to unplug the machine.
Loosen the screw that holds the needle in place (even though the needle is still stuck in place) and try moving the handwheel so the needlebar will raise to its highest position.
Try to remove the bobbin case from the machine. If the thread is tangled, you can try snipping (patiently and carefully) with small scissors and removing the loose threads with tweezers. Do NOT yank! Just keep working until the thread knot becomes loose enough to actually remove the bobbin case and the needle.
May 01, 2017 | PfaFF Sewing Machines
Ruffler foot bobbin tangles
I suspect that the bobbin thread you are talking about is in fact the top thread that has been pulled under the material, make sure that the top thread is pulled into the tention discs firmly and that there is no fuzz in with the thread, also make sure the top thread is properly threaded and is actually in the take up bar .
Apr 08, 2014 | Singer Inspiration 4206
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
My bobbing thread keeps jamming
Make sure you are putting the bobbin in right side up. Some times it will do this if your needle size is incorrect to the fabric weight.
Jan 13, 2013 | Janome Sewist 500 Sewing Machine
Lower bobbin thread gets tangled
try changing the needle --make sure the needle is the right one
for the fabric being sewed
try a different thread
make sure the bobbin is not over filled
make sure the bobbin is turned the right way in the bobbin case
make sure the thread has not come off the thread take up lever
Oct 04, 2012 | Brother XL-3500
My machine is jamming, the bottom threading gets way too loose. and jams the machine up. I dont have an manuel or any instructions.
Ironically, often times when the bobbin thread is knotting up, it's the top thread that needs the adjustment. Loos top thread thesion will tangle up in the bobbin cassing...Think about it for a minuted. Try a quarter turn to the right on your top tension and then go fro there. There could be a problem with the bobbon casing tension adjust screw and plate. but I doubt it...Nine times out of ten when the bobbon thread is tangles the top thread is too loose.
Sep 01, 2011 | Singer 3116 Simple
Birdsnest and machine jams
Ok, this is real simple. pull the thread from the bobbin up through the bottom of the machine near the needle. also, hold the thread that you threaded through the needle with the other strand on the left of the needle. hold them there for a few stitches... and wahla! no more birds nest.
May 10, 2007 | Euro-Pro Shark 80 - 7133
A horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Jan 05, 2007 | Singer 2662
Brother XR-65t Mechanical Sewing Machine Logo
3,686 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
