Question about Goldstar GVR-DD1 VHS VCR
Eating tapes I insert an 8mm cassette and it starts to play for about 2 seconds and then stops. When i press the eject button the cassette comes out but the tape is strung back into the machine. I have to pull the tape out and it is crinkled up real bad. When I insert a cassette and press play, ff, & etc. it starts to do it but stops and the tape is messed up again. The vhs side works ok. NEED HELP IN WV ted
Same problem with my unit. In my case the capstan motor was jamming. It was jamming because the metal coating on the capstan rotor magnet had peeled away and was interfering with proper rotation. This was happening even though the capstan appeared to move smoothly when rotated by hand.
If you really want to dive into this the fix is:
1) Unplug the unit from power.
2) Open the cabinet top and front
3) Disconnect the connectors going to the 8mm unit and remove it.
4) Disconnect the flex circuit connector going from the capstan motor to the 8mm drive's PC board.
5) Remove the capstan motor by removing the three Phillips head screws on the bottom of the 8mm drive at the base of the capstan motor
6) Remove the plastic drive gear on the capstan motor shaft
7) Pull the capstan rotor straight up away from the stator.
8) Examine the capstan rotor magnet for defects/peeling of the metal coating of the magnet. If the coating is fine, then you do not have the same problem as I did.
9) If the coating is peeling/damaged, you can do what I did by following the remaining steps
10) Peel off the failing coating to get a clean surface. Note, the magnet appears to be a loose ceramic and can be easily gouged/damaged. Becareful to not damage it any more.
11) The magnet will probably be retaining a lot for metal particles and dust. Apply adhesive tape to and around the magnet repeatably unit all contamination is removed. Tape pressed to the magnet should come back clean.
12) Seal the magnet. I used a couple of coats of clear nail polish to protect the magnet from further damage. Don't know if it really helps but it seemed like some protection should be added to the magnet and nail polish was readily available ("thanks honey").
13) Reassemble. Don't forget to reconnect the motor flex cable prior to installing the drive.
Posted on Jun 21, 2009
  • 579 Answers
This is the number one failure mode for a tape machine.
One drive is used to pull the tape out and run it across the heads very accurately, and another drive is used to pull the tape back into the cassette. This one uses a clutch to allow it to slip so that the takeup reel in the cassette can vary in speed depending on how much tape is on it. After a few years, it slips too much and can't pull the tape in fast enough. (older units use rubber idler wheels to do the same thing)
Either tighten up the clutch, or replace the rubber wheel.
Hope Ya Fix It!
Posted on Feb 01, 2008
Cassette stuck in the dash. eject button will not eject the cassette
You should take the tape deck out of the dash. Most aftermarket ones have two pairs of holes that you can insert long nails into to disconnect it from the dash. Unplug all the wires and open it up. It has probably eaten the tape and you will have to cut it and pull the strands off the capstan to get the cassette housing out. A pair of forceps, tweezers, and wooden handled cotton swaps and rubbing alcohol are helpful for cleaning and removing the strands of broken 3 7/8 ips tape.
Mar 04, 2015 | Chrysler 2002 Concorde LXi
Why does the tape get caught in my toshiba rd-xv45kb recorder when i try to eject the cassette and the tape snaps
Not sure about the Toshiba but generally when inserting a cassette it is lowered onto the tape drive. There is a device that will register the presence of a tape which used to commonly be a phototransistor or similar mounted on a short post that is covered by the cassette.
Once the machine knows a tape has been inserted, when play is pressed two vertical rods move towards the heads dragging the tape with them enough for it to make contact with the sound head and wrap part of the way around the video head to make playback possible.
When stop, forward or reverse winding or eject is pressed those two rods move back to the starting position and the surplus tape is wound back into the cassette.
If a cassette ejects leaving a loop of tape that can mostly be pulled out little damaged the reeling in mechanism isn't working. If the tape is jammed and comes free only after breaking the rods aren't returning to the start position.
Engineers use an empty cassette case suitably modified so once the vcr cover has been removed the operation can be observed. The problem might be a worn belt or rubber drive wheel or a problem with the hidden linkages - or it might be an electronic problem.
Apr 22, 2017 | Toshiba Televison & Video
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
I have an older (1996) Sony Handycam CCD-TRV211. I am using the player to transfer my old 8mm tapes to my computer. The player will play for about 4 seconds then stop. I get a blinking triangle with a...
How are you powering the camcorder ? Many will not transfer videos if battery powered, since the battery may fail. Try again with the camcorder mains powered, see if that helps. Have you cleaned the heads with a cotton bud and a little IPA ?
Mar 01, 2017 | Cameras
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
I have a Sony CCD-FX410 8mm camcorder. It is in excellent condition. I was going to transfer all my 8mm tapes to DVD and decided I should get a head cleaner for it. Found one at BestBuy, put it in and it...
This is my 3rd try to get a solution. I have a Sony 8mm camcorder, CCD-FX410 and a head cleaning tape is stuck in it and I can't get it out. This camera is in EXCELLENT condition. I tried going to Sony's website and they no longer offer service on it. Both of the other people who answered this told me to turn power off, unplug cord, turn on to VTR and wait 15 seconds, then plug cord in again. It didn't work. After I put the head cleaner in, it wouldn't play and kept trying to eject. Finally it just started beeping and flashing an icon in the viewfinder. Manual says to send for repair. Any ideas on what I can do? Can not get tape ejected. Thank you.
I know CCD-FX410 camcorder was launched in July 1992 and I also know what is the reason of problem in your camcorder and I'm afraid it can not be solved because its an old piece now. Parts are no longer available and problem is leaky electrolytic capacitors on its circuit boards. Time factor is involve here, it is not operational mistake.
I can help you out to eject stuck head cleaner tape in camcorder. If you are looking to bring it back in business then it is not possible because an experienced camera tech can repair it and will charge you more then camcorder worth.
Hit "add a comment" button to assist you in ejecting tape. You need to apart camcorder and should have 4 or 6 volt DC supply in hand.
Thanks.
Apr 19, 2009 | Video Cameras
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Eats tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Televison & Video Logo
213 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
