Question about Sony MDS-JE520 Mini Disc Player
MDS 503 STUCK IN STANDY MODE?
MDS 503 IS STUCK IN STANDY MODE,AND WILL NOT SWITCH ON.THE STANDBY LIGHT COMES ON OK,BUT DOES`NT RESPOND WHEN PRESSED.ANY IDEAS,ANYONE,PLEASE?
  • HW_Dude
    HW_Dude May 11, 2010
    Does the unit respond to IR Remote control commands ?
  • HW_Dude
    Does it respond to the Remote Control ?
  • Sony Expert
  • 509 Answers
Is it an MDS-JE530? Do you have a minidisc in it? If yes, then unplug the unit. Slide the little switch from TIMER "OFF" to "PLAY", then plug the unit back in. After 10 seconds, it should turn on and start playing the minidisc. Let me know if that works or if we need to try something else, okay?
Posted on Aug 10, 2010
This worked for me:
1. Disconnect power.
2. mainboard - take out jumper cn451, near the battery.
3. Connect the power.
4. Now the minidisc is working OK.
5. Turn it off.
6. Put back the jumper.
Posted on Apr 24, 2011
SOURCE:
Sony mini disc recorder mds 501 stuck in standby mode; doesn't respond to any commands
It could be more than just a switch but maybe the tact switch for the power is not working. It might need to be replaced. It may be a job for a technician as sometimes the face plate has to come off to get to the board with these switches mounted in it. I have replaced some switches and that was the answer- it should be pretty easy to determine in the right hands.
Jun 01, 2012 | Audio Players & Recorders
Power switch
The red standby light is always on. It should only change when you press 'power'. When you turn it off, it is on 'standby', meaning you can switch the switch to make it start-up in play or record mode by using a timer and the switch below the power switch. This is normal for Sony.
Feb 24, 2012 | Sony MDS-JE330 Mini Disc Player
Lap top stays in standby mode Model Compaq
check whether the charger adaptor its connect properly. Then press down the shut down button, dont release it on till the indicator light for standy is off. You press the button again to on it.
Nov 21, 2009 | Computers & Internet
Onkyo DV-SP301 DVD player stuck in standy mode
Had an Onkyo DV-SP301 that would only intermittently come out of standby. Found faulty resistor R2 on the power supply board (board ORTP-865), it was nominally 5600 ohms, measured much higher. This after checking most p/s caps! R2 runs warm when unit is in standby, so you may want to replace with a higher power rated resistor. I used same rating but 10 k ohm instead, worked fine then.
Nov 28, 2008 | Onkyo DV-SP301 DVD Player
Mini Disc Not Working
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
Oct 06, 2008 | Sony MDS-JE480 Mini Disc Player
Lamp
I'm still not sure about your question. Let me quess that by saying power/standy light goes to red...that mean your computer
is going into standby mode.!!!! So do it this way..on the left or right top corner of your notebook not the monitor, you should be having a small pin pointing up..I think that pin is use when you close the lid of your Laptop and it make your laptop goes into standby mode.When I mean goes into standby(sleep mode) the first think you can notice that your monitor light will be off and you can still see a very light image.So maybe this pin is stuck try to push it down for several times..
best of luck, takecare
Theknack.
Apr 19, 2008 | Computers & Internet
Not Working!
Hello, I will try to find you the Service Manual. Please leave your email. Best regards, Arpi
Jul 25, 2007 | Sony MDS-JE480 Mini Disc Player
Sony MDS-JE520 Mini Disc Player Logo
761 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
