Question about Sony VAIO PCG-K35 Notebook
Xbox live on this laptop
Ok, im trying to configure the ethernet port on the laptop to be able to share the internet with my wireless card. on the control panel in 'network and internet connections', and it says:
-set up or change your internet connection
-create connection to the network at your workplace
-set up or change your home or small office network
-set up wireless network for home or small office
-change firewall settings
which do i do to configure the ethernet for xbox live?
PLEASE HELP!
    Genius:
  • 1,554 Answers
I assume you have a crossover ethernet cable.
put the my network places on your desktop.
right click on desktop/properties/desktop/customize desktop/tic
then on the network places icon on desktop right click/properties
right click on wireless and bridge devices
they are now sharing the same ip
be sure and remove /delete bridge when not sharing as the ip will stick forever likely.
that should do it if you need more info /open my computer and hit help and search for internet connection sharing as the firewall may need to be configured.
Posted on Jan 30, 2008
6ya staff
SOURCE:
Cisco access point
How to configure wireless access point using a laptop
Wireless technology makes connecting to the Internet possible from anywhere within the range of the network. Unfortunately, not all Internet-capable devices have wireless technology, and many still require an Ethernet port connection. If you have a laptop with a wireless card and an Internet connection, you can make the laptop a wireless access point and share that connection with other devices, whether your laptop runs a Windows or OSX operating system. Windows computers allow other devices to access the wireless network via a physical connection to the laptop, while OSX computers allow AirPort equipped devices to connect as well, creating a second wireless bubble for the network.
Instruction:
WINDOWS
1 Turn on the laptop and the device with which you will share the connection. Ensure the laptop's wireless card is turned on and you have an Internet connection.
2 Connect an Ethernet cord to the port on the laptop, and the other end to the receiving device. You need to make the connection first, or you will not be able to access the sharing options for the connection.
3 Open the list of network connections on the computer. In Windows 7 and Vista, access this list by typing "Network Connections" into the Start menu search bar and pressing "Enter." In Windows XP, click on "Network Connections" in the Network and Sharing Center section of the Control Panel.
4 Right click on the wireless connection and select "Properties," then navigate to the Sharing tab. This tab will not appear unless both devices are connected.
5 Check the box marked "Allow other network users to connect through this computer's Internet connection." Click "OK" to save the changes.
OSX
1 Click on the Apple menu and select "System Preferences." Click the "Sharing" option, then choose "Internet Sharing."
2 Select the Airport and wireless network in the "Share your connection from:" drop-down menu.
Select an output format for the connection in the "To computers using:" drop-down menu. Choose "Ethernet" for a physical connection or "AirPort" for wireless broadcasting.
Turn on the device you wish to receive the connection. Connect the devices with an Ethernet cable, or turn on the receiving device's AirPort card and connect wirelessly.
Dec 12, 2011 | Computers & Internet
HOW TO LINK LAPTOP TO PC
If you wish to connect your laptop to your PC for sharing the resources and files. You can use Either a Wireless network or Ethernet adapter. Since you are looking for a small setup (I guess so). You can configure an ad hoc network.
Most of the latest laptops comes with a Wireless card and and ethernet card. However in the case of PC's there might not be a wireless card. If you are looking for portability and working from distances (say from the other room) then you can buy a wireless card for your pc and setup a small wireless network.
Okey let us see how to setup an ethernet connection (it's a wired connection between your pc and laptop to enable networking between them)
You need to make sure both your computers have an ethernet port and you need a Crossover cable to connect between them (get at least 3 meters so that it will be more comfortable.)
A similar port will be there in your laptop too. Connect your crossover cable to both pc and the laptop (you can buy a cross over cable from most of the local computer shops).
Now you need to setup the ip addresses for both the computers.
Let's set 192.168.1.1 for your laptop and let's use the same ip as a gateway. We will be using 192.168.1.2 as the ip address for your pc and the same gateway (192.168.1.1). Now let's see how to setup IP Addresses
With the following instructions you can fill the above values in both the laptop and pc by individually repeating these instructions given below. Once you set both the ip addressess and gateways your network is ready to go. (You don't have to worry about the dns addresses since we are setting up a small network of two computers)
In your case the connection name will be unknown or something like that where as in the image it is Internet.
If you are on Windows Vista or Higher, Go to Control Panel (Start menu -> Control Panel)then click onNetwork and Sharing Center and you can see your active connection there; click on the View Status
Then a new dialog box will appear; click on the Properties button there
once you have in the properties dialog box; double click on the Internet Protocol Version 4 (TCP/IPv4).
Now you will get a new dialog box where you can insert your ip address, gateway and dns.
Now you are all set and ready to go.
If you have trouble following this solutions please mail me at nextdoornerd AT gmail DOT com and I will help you.
Jul 28, 2010 | Network Computing Devices (NSH800S/A)...
How do i share internet with others when I suscribe to internet I was told when I signed up with Tmo that windows settings allow you to share connection.
Windows Settings allow you to share your internet connections providing you have 2 network connections IE: 2 X Ethernet cards 1 X Ethernet Card 1 X Wireless Card. Then on the computer you want to "share" the internet on click on control panel /Network then right click on the card that is connected to the internet you want to share. got to Properties then advance . Tick the box "Allow network users to connect through this computers internet connection" Reboot that PC and any pc connected to that PC either by network cable or wireless will be able to use the internet
Jul 24, 2010 | Dell Inspiron Mini 10 Notebook
I cant get my router working
    Connect Equipment
  1. Turn off your computer and disconnect the Ethernet cable running from the back of the computer. Plug the cable into the port marked "Internet" on the back of the router. Plug the blue cable included with the router into one of the four LAN ports on the back of the router and plug the other end into your computer Ethernet port. Turn the modem on and wait two minutes. Plug in the router and wait one minute. Then turn on your computer. After two minutes the router should have four status lights glowing on the front panel: power, Internet, wireless and LAN.
  2. Configure Router
  3. Open your Internet browser on the computer. The router will automatically display the Smart Wizard configuration page. Click "OK." On the next page, enter the region where you are located and your wireless networkmag-glass_10x10.gif name (SSID). The default is "NETGEAR," but you should change it to a different name you can easily remember. The name is case-sensitive. Click "Next." Then click "Done."
  4. Configure Computer for Wireless Access
  5. Go to "Start" and click on "Control Panel." Open "Network Connections" and right-click on "Wireless Network Connection." Select "Properties." Then select the "Wireless Networksmag-glass_10x10.gif" tab. Check the box to use Windows for network configuration, then click "Add..." Enter the same SSID name that you entered when you set up the router. Select "Disabled" for data encryption as that is the router default setting. Click "OK." Now try to connect to an Internet website to verify connectivity.
  6. Router Logon
  7. To log on to your router, go to Routerlogin.net. Enter "admin" for the user name and "password" for the password. On the router home page, go to "Set Password" and change the router password. Then choose a security protocol to use that is compatible with your computer's wireless adapter. WPA-PSK is the best choice if your wireless adapter supports it.
Dec 14, 2009 | NetGear WGR614 Wireless Router
Unable to connect two wireless laptop for internt sharing
Make sure your computers are set to DHCP instead of static.
Sep 04, 2009 | Dell Inspiron 6400 Notebook
Use Incoming Wireless to Send Out Ethernet *Internet Sharing*
http://windowshelp.microsoft.com/Windows/en-US/help/bfd3bd31-82f0-4b9c-9cde-fb92bc2b14771033.mspx
Enabling ICS
To enable ICS, on your host computer:
1. Open Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections.
2. Right-click the connection that you want to share, and then click Properties. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
NoteThe Sharing tab will not be available if you have only one network connection.
4. If desired, you can also select the Allow other network users to control or disable the shared Internet connection check box.
5. Optionally, to allow other network users to use services running on your network, click Settings and select the services you want to allow.
When you enable ICS, your local area network (LAN) connection gets a new static IP address and configuration, so you'll need to reestablish any TCP/IP connections between your host computer and the other network computers.
To test your network and Internet connection, see if you can share files between computers and make sure each computer can reach a website.
Once you have done the above, connect the Ethernet cord to the WAN/Modem port on the Linksys router and set the router to Dynamic IP. Then connect another computer to one of the LAN numbered ports on the router and they will have internet. Remember your computer MUST be on for the computers connected to the Linksys to get internet.
Jun 26, 2009 | Acer Windows Vista TL-562G Notebook
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
URL Filter Configuration
Ok, sounds to me like the security settings on your laptop for the wireless network card are configured in HIGH safety mode. The easiest way to resolve this is to:
1. goto control panel (start - settings - control panel)
2. open network connections
3. right click and select PROPERTIES on your wireless network connection
4. click on tcp ip (interent properties) double click it
5. goto advanced button (lower right hand side)
6. options tab
6. goto properties button for ip filter
7 uncheck (if checked) Enable ip filtering
that should fix ya up.
Dec 29, 2008 | Computers & Internet
Xbox 360 with this ethernet port?
It is possible to do that, but u have to configure ur ethernet port to allow a pc to access the internet thru it. it's simple.
control panel-network-create a new network and follow the prompts..
Good Luck
my xboxlive game tag: mystic00l (it's a L not a 1)
Jan 29, 2008 | Sony VAIO PCG-K35 Notebook
Ethernet not working! Help!
im assuming its not dissabled, if not then go to control panel, network connections and right click on your network card and go to properties then driver and see if there is a code 9 meaning it's faulty or the device is working. if it is faulty then it's part of the motherboard anyway and you will have to buy a pcmcia network card and connect through that instead
Sep 04, 2007 | HP Compaq Presario V2000 Notebook
Sony VAIO PCG-K35 Notebook Logo
134 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
