Question about Dell E171FPb 17" Flat Panel LCD Monitor
Does not power on
My monitor was working great at my office until I brought it home and it won't power on. Weirdest thing ever. Didn't drop or anything. No juice and I verified power source. Any thoughts?
    Novelist:
  • 103 Answers
Hi Mia,
Hope this tips can help figure out the problem; If AC mains or AVR is good, review checking the power cable connecting from AC mains/AVR best fittingly. Or try connecting the monitor on different outlet. Just be careful in handling connecting end to AC source always. Try another cable if you have extra one. If the problem persist there might be internal problem on your monitor. Busted fuse or cold solders before you transport causes the problem. You'll need technical guy to check internal of the monitors due to high risk of Voltage Shock. Please be guided.
Best regards,
Rosener Guyano
Posted on Jan 30, 2008
LG flatron l1915s monitor, green led flashing only when coming out of standby resulting in no picture
Check the electrolytic capacitors inside in the power supply board portion. replace all busted ones.
Jan 10, 2014 | LG L1915S 19" LCD Monitor
Hp Compaq nx9010 Won't connect to Internet
install the latest service pack, i'm sure that's probably the issue, the early version of win xp didn't like to cooperate with wpa or wpa2. to check which service pack you're running (i assume xp because that's what came stock on those) click start and go to my computer and right click then go to properties, it will tell you which service pack you're running. the latest is service pack 3. honestly if i were you i'd just do ALL the updates as there are many security updates and patches you should have.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 09, 2012 | HP Compaq Business Notebook NX9010
I have a hp v75 old desktop computer that I brought from my garage, I got everything plugged up, but the monitor wouldn't show anything.. I googled it and I didn't think it would work but I just...
As your monitor had showed up once before, I assume it is still in a good condition. The next time, you were not able to wake up the monitor by pressing the power button on your CPU cabinet, which means, the power supply to the monitor may have been interrupted. To check whether your monitor is working properly, plug it to any direct connection and see if the power button on the monitor is flashing. If this works, get everything plugged up, check all the connections properly and try to run the computer again.
Hope this helps, Mrityunjay.
Jun 28, 2012 | Computers & Internet
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
I have a 2000 Lincoln Navigator. About 2 weeks ago, my air compressor for the suspension quit coming on, and my back end sank to the frame. I read online that it is probably the solid state relay, located...
Wow. I have a Mark VIII, so I can empathize...they really load these things up with electrical controls, and I know from experience to start with basics-get a digital meter and check your battery voltage when the car has been sitting for a few hours, it should be 12.5 volts. Next, check voltage when running-it should be about 15 when first started, gradually dropping down to about 14.2 after a few minutes. I cannot emphasis how important good power is on these power-hungry systems.
Check your connections at the battery, make sure the terminals are immaculate and the lugs are too-and you might try removing BOTH clamps and hold them together for a few minutes to discharge electrical components. Hook them back up (always hook up the positive cable first), and start the vehicle and let it idle for 5 minutes-then gently drive it for another five, to reset sensors. Assuming your battery and laternator are good to begin with, if you still have the problems you describe, you probably have a major malfunction with modules or even the ECM, something the dealer will have to diagnose with a Tech 2 scanner.
Jul 19, 2011 | 2000 Lincoln Navigator
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
Dell E171FPb 17" Flat Panel LCD Monitor Logo
152 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
