Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Singer futura CE-200 Can not wind the bobbin thread
This is the first time that I have played with the SInger Futura CE 200. I have it set up in embroidery mode and I can not get the bobin to automatically wind. When I turn the machine on I get green light when I push the start button it turns solid red but the bobin does not wind.
Any help would be appreciated.
Jenn
  • 1 more comment
  • asimov2of4 Feb 04, 2008
    Thanks, This solution works. I tried looking for that information in the manual but did not see it any where. In addition to your solution I found the answer on SInger's Technical help FAQ page. This system seems complicated but I won't let it beat me. I am too stubborn for that.
  • Anonymous Mar 12, 2014
    Bobin
  • Anonymous Mar 16, 2014
    singer future ce 200 video
    New Friend:
I have modeo4562 l need your know why is the bobbin winder not spinning ?
Posted on Jul 04, 2015
  • 48 Answers
Use it as a regular sewing machine. install the bobbin and push it against the carrousel. push the pedal and it should go.
As Embroidery mode you have to send a design for the machine to work, then put the bobbin against the carrousel and when you hit start it should go.
Posted on Nov 11, 2011
Has anyone used the quantum futura CE200 with Vista . I am having trouble loading the software with Vista. Does anyone have any tips? Thanks for any info.
Posted on Oct 27, 2008
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Posted on Feb 03, 2008
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Singer ce-200 jerks between stitches only when it goes slow.
Are you using a good quality bobbin thread? Is the machine cleaned and oiled? Is the bobbin in place like it supposed to be?
Oct 31, 2011 | Singer CE-200 Quantum Futura Computerized...
Singer futura 250. while sewing the E4 code
Are you using bobbin thread? Is your thead new? Is themachine threaded correctly?
Make sure that when you thread the upper part the thread go under the circle that pull it.
Another thing is that when you hit the start button, pull the upper thread until the machine goes two or three times. It helps the bobbin thread to come up and the machine start sewing.I you leave it along the thread sometimes doesnot comes up and that is why the machine beeps.
I use this technique to make sure it doesnt beep and to cut the thread (the one at the beginning so it doesn't mess my design)
Feb 15, 2010 | Singer CE-200 Quantum Futura Computerized...
Where can I find threading, and bobbin winding instructions for a singer 9133?
Although your model may not be listed exactly, this link ought to provide other models similar enough to yours to be of assistance.
HERE
Your User Manual ought to have this information too
Aug 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Bobbins
When you engage the bobbin winder it has a small rubber in which it makes contact with the driver rubber maybe that is not making contact, to stop the cotton from showing on the top, adjust the small screw on the bobbin holder tighter clockwise.
Feb 26, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
While sewing on singer quantum futura ce-200 sewing machine, thread bunchedup on underside of fabric and bobbin case flew out more than once.
Mine did this and it seemed impossible to fix. My problem was a tiny bit of thread stuck in the bobbin cover (but it could be anywhere in the thread route). I ran dental floss through the path the thread follows and also in the bobbin cover and poof out came a small piece of thread that all my looking missed. Hope this helps.
Dec 27, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
462 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
