Question about Nokia 6103 Cellular Phone
Handset settings for nkia 6103
My nokia 6103b had some water spilled onto it and now I cannot get it out of headset mode. I can call out and receive calls, but cannot hear or be heard due to being in headset mode. (there is a little pic of headphones in the middle of the display). Please help.
  • 3 more comments
  • Anonymous Feb 13, 2008
    no signal and with wrong settings
  • ro_kchorro Mar 05, 2008
    no tengo señal, aparece un cartel "falló registro tarjeta SIM" cual puede ser el motivo?????????????
    IMEI 35 93 72 00 73 55 126
    MOVISTAR
    espero una pronta solución
    muchas gracias!!!!!!!!!!!!!!
  • Angelica21 Apr 21, 2008
    I have the same problem, the little headset picture is in the middle of the screen on my nokia 6103 and can't seem to get rid of it, I took the battery out of the mobile while it was still on and that didn't fix my problem i even restored the factory setting and still didn't fix my problem, please help, i can recieve and make calls but just can't hear them unless they are on loudspeaker.
    Please Help
    Thank you
  • Anonymous Aug 19, 2008
    i have the same problem. i tried about everything
  • danielroark Sep 11, 2008
    This sounds like it would've helped...6 months ago. We replaced the phone shortly after the post.
    Scholar:
  • 87 Answers
I posted this solution for someone with the same phone with service issues. Follow the same steps to disassemble and clean. The phone has corrosion from the moisture on the backside of the plug on the bottom. This is fooling the phone into thinking that there is a headset plugged in when there is not. Let me know if this helps. And please don't forget to rate. Feel free to contact me via email if you need additional help. Solution #1 posted on Sep 11, 2008 handset settings for nkia 6103 - 0%20stars.png
noavatar_s.gif Daelmyth
Rankhandset settings for nkia 6103 - guru_s.gifsrc="http://i.fixya.net/uploads/images/guru_s.gif" alt="guru_s.gif" class="h_mi" /> Guru
Rating: 87%, 19 votes
Get a T6 screwdriver, remove the battery cover, battery, and sim. Next, gently pop off the antenna cover at the top of the phone exposing 2 of the 4 screws in the back of the phone. The other two screws are already visible near the bottom of the battery compartment.
After the 4 screws are removed, carefully use your fingernail or small flat tool to seperate the back of the phone (D housing) from the keypad housing (C housing). Once this is seperated, you will see the back of the main motherboard. Lift up on the board gently from the bottom. You will notice that at the top, the main cable plugs into the board. GENTLY unplug this cable. Be very careful not to damage the plug or the channel.
Once the cable is free, the board will pretty much fall out of the phone. On the back of the phone (the one with all the heat shields) - you can pop off the heat shields with a small screwdriver or knive CAREFULLY!!!! Remove them all. Look for any signs of corrosion, especially at the top and top right. This should be right above the battery contact terminals. This is where your RF modulator is.
Brush the entire back of the board with 91% rubbing alcohol and a soft to medium bristled toothbrush.
Also, make sure your phone still has an antenna. Sometimes, if this model phone gets dropped, the antenna cover will pop off and the antenna will go flying (just snaps into the back housing). Many people pick up the cover and snap it back on, not realizing they are missing an antenna. To see what the antenna looks like, go to ebay and search for a Nokia 6102i, or 6103 antenna. If your phone does not have this part, order it, snap it in place so that the little metal contact will touch the main board and you're good.
If you do have this part in place, then continue with the alcohol bath. Also, on the front side of the board, you will notice a white sticker which retains all the surface switches of the phone. You can very carefully peal this off exposing all of the contact surfaces for the switches. Make sure this is clean as well.
Dry the phone with a hairdryer. (Rubbing Alcohol evaporates fast, but it lingers longer under the chipsets so it is good to bring the temperature of the board up to speed up the process). A hair dryer won't get it hot enough to do damage.
Once you are sure all the alcohol in the phone is dry, reassemble the phone in reverse order of the way you took it apart.
Let me know what you find out after performing the above steps. If you find severe corrosion, email me. daelmyth@yahoo.com
Posted on Sep 11, 2008
  • Chris Havens
    Chris Havens Sep 15, 2008
    HaHa! Didn't notice the date. LOL.
SOURCE:
Help me unblock nokia 6103 imei# 353663/01/622281/0
go to tools and settings. then select security setting and configure ur security system. it is such lock ur phone and it asked ur security code ur default code 12345. thanks
Jul 28, 2009 | Nokia 6103 Cellular Phone
I can't seem to unlock my nokia 6103b it is locked to t-mobile
You can use the following link to visit the website, where you can find the master lock code for your Nokia Handset by just entering the IMEI number;
http://www.nokialockcode.com/calculate.php
Feb 02, 2009 | Nokia 6103 Cellular Phone
Unlock code for a Nokia 6103b
Jan 22, 2009 | Nokia 6103 Cellular Phone
Nokia 6103b
Jan 21, 2009 | Nokia 6103 Cellular Phone
Nokia 6103b
Hi Ferggi,
Try the following codes...
#pw+ 449 107 564 703 215 +1#
#pw+ 387 536 003 557 345 +2#
#pw+ 236 995 155 401 404 +3#
#pw+ 338 906 256 621 311 +4#
#pw+ 152 304 475 035 712 +5#
#pw+ 008 233 326 674 740 +6#
#pw+ 045 813 764 370 527 +7#
Nov 02, 2008 | Nokia 6103 Cellular Phone
Forgot security code for my nokia 6103b
Need help unlock nokia 6103b imei 354814011369325
Sep 23, 2008 | Nokia 6103 Cellular Phone
Need to unlock Nokia 6103
please provide me code to unlock nokia 6103b
IMEI no. 359371/00/539958/1
Code no. 0533508GN03B8
Jul 29, 2008 | Nokia 6103 Cellular Phone
Nokia 6103 restriction code required
hi
please help me i am in usa when i change my sim, it aske me restriction code.
i have a nokia 6103b phone IMEI no. 359371/00/539958/1 & cide : 0533508GN03B8
please help me about it restriction code
thanks
pranav
May 29, 2008 | Nokia 6103 Cellular Phone
Nokia 6103b
i think the difference between 6103 to 6103b in the band
the 6103 has a 1900/1800mhz
the 6103b has a 850/900mhz dual band phones
Sep 01, 2007 | Sony Ericsson K750
Nokia 6103 Cellular Phone Logo
98 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
