Question about Sanyo HT32744 32" TV
SANYO HT32744 THIS IS A 2006 YEAR AND ONE OF OUR STUDENTS ROLLED IT OFF A STEP IN THE HALL. BEST I CAN TELL ALL THAT WAS BROKE WAS THE BOARD THAT PLUGS DIRECTLY ON BACK OF THE PICTURE TUBE, PART # 1AA4B10B0960A. I THOUGHT IF IT WAS NOT VERY HIGH I WOULD SEE IF THIS WOULD FIX IT. BUT I DONT KNOW WERE TO BUY SUCH A PART. THANKS FOR YOUR TIME. CARY
  • 281 Answers
Make sure that the neck of the tube is not broken, and then trace the broken lines on the board and solder them, there are not many components on that board. If the main board is intact you can fix this is up, and I hope all the components are in good shape. Good luck.
Posted on Feb 01, 2008
What is a good excuse for not doing my homework and not going to detention?
There is never a good excuse for not doing homework. When I was in school, I used to say that I forgot my book at school and would get it done in study hall that day.
Jan 04, 2017 | Homework
F8E0 0n whirlpool gas range M: weg730hod50, What is going on, this is only 1 year old?.. reset and continues to error...
F8E0
Cooling Fan Speed Too Low
Fan speed below 500 rpm, either because the fan is spinning too slowly or because there is a problem with the Hall Effect sensor.
When will occur:
Within 20 seconds of a fault condition when cavity temperature is above 170°F (77°C).
RECOMMENDED CORRECTIVE ACTION PROCEDURE
1.Unplug range or disconnect power.
2.Pull the range forward and remove the top access cover.
3.Verify there are no obstructions in the blower. If there is an obstruction, remove it and go to Step 6. If no obstructions, go to Step 4.
4.Disconnect control board connect or P5 and check the fan motor for 105? resistance between P5-1 and
P6-3. If the motor test is not good, replace motor and go to Step 6. If motor tests good, go to Step 5.
5.Check the Hall Sensor by removing the control board P7 connector and testing for 5 VDC between P7-7 and P7-1. If test
is good, go to Step 6. If test results are not correct, replace the Hall Sensor.
6.Replace all parts and panels before operating.
7.Plug in range or reconnect power.
8.Start a cook cycle and check for proper operation.
9.
Enter the diagnostic mode to view the "Faults" screen. Press START TIME or DELAY START to clear each Fault code(s).
Nov 19, 2016 | Whirlpool Kitchen Ranges
Sanyo 1LG4B10Y04800 how do I find out what board my television takes this is the Power Board number
Assuming you are observing all ESD & Safety precautions...
The absolute best way to tell what pack you need is to LOOK at your old pack...
Go to a parts supplier...
Put in your make = SANYO
MODEL = something like "DP42841"
that ought to be a Sanyo Lcd tv ...
such as ... shopjimmy.com
ebay.com or amazon.com
Sanyo 1LG4B10Y04800 Power Supply
TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 16, 2016 | Sanyo Televison & Video
Tell me some idea about definition essay.
Actually i don,t know well about it.But i think its like dissertation paper.You can get help about it from your teacher.Or you can search on online.I am suggesting you try a provider to know well about it.Here is one provider try it http://www.poweredessays.com/. It can give you best idea about it.
Dec 05, 2013 | Custom Essay Cheat Guru
My tv sanyo lcd 42 dont has imagen no sound
The main power supply regulator bard to your TV should be troubleshooted. This is a very skilled work and fatal too, for an unexperienced one to work with. it will be best for you to contact any experienced service technician. In most cases, the board might be replaced as card basis.
Jun 21, 2012 | Sanyo Televison & Video
It stops mid cycle and at the digital display it flashes " LE " . What is wrong????
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Apr 11, 2011 | LG WM1812C Front Load Washer
2001 audi drivers side window will not roll up
can you hear the motor working? its possible the motor/regulator assembly has given up. have someone who knows audis' look at this and if the repair is too pricey given this joyous time of year(LOL) have them at least bypass the motor and prop or secure the window into place until the neccessary repairs acn be made. happy holidays.
Dec 28, 2009 | 2001 Audi allroad
BOSCH RANGE HGS3052UC ERROR 160 AFTER REPLACING PANEL
f160 is cooling fan error
board not reading hall sensor on cooling fan
could be cooling fan not turning
hall sensor on end of motor not plugged in or hall sensor broken
Nov 24, 2017 | Bosch HES 232 / HES 236 Electric Kitchen...
Sanyo HT32744 32" TV Logo
37 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
