Most times when electronics stop working on pc's is because of 1. bad drivers or 2. equipment issue it self. It is quite easy to see is it 1 or 2. Try to remove software for the Web Cam and keep camera unpluged and then reinstall software and only plug in camera when software tells you to do so. Also try to use diferent USB plug on your pc than the one you usually use with Web Cam. Once this is done if it does not work try installing it on another computer. It is a quick check and software is easy to uninstall. Make sure to back up your photos just in case of some kinda problems during uninstall. Good luck.
