Home | Electric Fans | Electrical Problem
Electric Fans
Problem for Electric Fans
Generic problem for all Electric Fans
Electrical Problem
By rclancette on Jan 30, 2008
installed a carriage house 2. Light kit works, fan does not. took apart, investigated... white electrical connector between fan and light kit sparks blue... fan runs. wiggle some more, fan stops, wiggle some more, connector "lights up" fan starts... and so on..
I'm not sure whether its the light kit side, or the fan side, or both. But...
any advice?
Comments:
Feb 01, 2008
- suggestion was correct, assuming connector was customer installed. But faulty connector is factory installed. Fan is under waurrantee. Thus, suggestion voids that. Simple matter of order the new part, then hurry up and wait. Connector is not a wire nut, connector is (I think it was 6) conductor wiring harness. The most immediate solution would have been to just cut it out and wire direct. But, as I said, "waurrantee." TY for the suggestion.
Same Problem
Feb 22, 2009
-   I have the same problem. The light goes on but the fan does not. I did wiggle the wires but nothing. -   chulo69680
Mar 26, 2008
-   when I turn on the fan first two lights come on very low. the fan will not come on at all. Do you have the electrical diagram for this light.
Hampton bay 40093 celing fan and light-   Guest
Best Solution
posted on Jan 30, 2008
Very Helpful)
24 seven
Rank: Wiz
Rating: 82%, 1397 votes
the original connector was not assembled properly. If the original was a twist on type, then unscrew it. Otherwise, remove the connector by cutting it off with cutting pliers. Now strip back insulation from the 2 wires about 1/2 inch and then twist the 2 together. now screw on a wire connector (tightly) that you must purchase (sorry) in an electrical hardware store. Finally, wrap electrical tape around both the new connector and wires to prevent unraveling.
Comments:
Feb 02, 2008
- oh, so "Fan is under waurrantee..."...so I get at least a 3 diamond rating then, right? after all, the "Fan is under waurrantee...".
Was this helpful?
Yes
No
Popular Solutions for Electric Fans
Questions and Unsolved Problems for Electric Fans
Answer
I am trying to decide whether to purchase Fanimation Belleria FP4320 with finish that is... (More)
Answer
how do i reverse my remote controled Hampton Bay ceiling fan
Answer
Nutone 668RP . The heat portion runs for about 10 seconds and then quits. The other portion of the... (More)
Answer
fan stopped working received new part from Hampton need installation manual, need wiring diagram and... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Electric Fans:
Top Electric Fan Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Electric Fan Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
