Question about MPC Computers AOC 7F 17" CRT Monitor
Monitor not Display
I notice that my samsung monitor is not displaying. I observed that the LED Power is flickering. And I hear sounds like relay inside the monitor. Please help me!
    Novelist:
  • 103 Answers
Hi Rey,
Hope this helps you like what I did to resolve this kinda problem. If you can manage to open the chassis/cover check first if the HOT (horizontal output transistor) is good, if good check the SMPS (switching mode power supply) primary and secondary side if there are short filter capacitors, diodes, transistors and open resistors. Major faults to consider is by checking the load of SMPS, control circuit, driver circuit, feedback ckt.
Please let somebody to assist you (a certified technician) how to open the chassis safely due to electric shock. Please be guided accordingly.
Best regards,
Rosener Guyano
Posted on Jan 30, 2008
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Whats the problem with no picture on the monitor but the cpu is working
Can you observe any LED lights on the monitor panel when you try to turn it on. If no then check your power cables. If you can see the LED lights but screen does not show try to unplug the VGA/HDMI cable and clean it by blowing air through the plug and then reconnect it. Also try to turn on the monitor without connecting it to the monitor as this will verify if the monitor is OK because if it is it should display a message to check the input signal or no input signal is detected. If it does and you are still not having a display then the problem is probably in your CPU and more specifically in the VGA card.
Sep 23, 2013 | Samsung Computers & Internet
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
I have prolem in samsung LED that no display shown when i turn on....can you please advice. thanks....Peter
send me detail on jogindersingh47@yahoo.com 1) if yours LED power on and display of window not giving then problem from cpu. a. first replace yours RAM and check display. b. then display cable and check display. c. Install new Display card and check display, if not giving display it means motherboard have a problem 2) LED not giving power on then problem from monitor a. replace monitor power cable and check display b. monitor logic card have aproblem
Mar 16, 2011 | MPC Computers AOC 7F 17" CRT Monitor
Monitor in on/off loop. If hold select button down you can see the PC is diplaying but monitor keep going off then on. Also can hear the relay clicking in the monitor.
That is a bad one. Sounds like you need a new relay. I know that is no help. Check the power cord, (believe it or not, they can have too little power going through if they get damaged or weakened by something). Check CLOSELY the video cable to computer connections. touch the ends and nearby cable ends while observing monitor to see if it flickers at the same rate of your movements. Try another monitor to see if it does the same thing. I can't help with much else on this. Good luck
Brock
Jun 02, 2010 | Fujitsu Siemens Siemens Basic Line B17-1...
LG 700E monitor's power LED blinking continueously, no display
LG 700E monitor's power LED blinking continueously, no displaySolution.............
Jan 23, 2009 | LG Studioworks 700S 17" CRT Monitor
When i turn my CRT on, after a few seconds my screen goes blank, then displays again, while this thing is happening, i can hear something switching... power led is on(green)... even when the display goes...
It sounds to me that the monitors power supply is dying. I would replace it with a different monitor as soon as possible. I would consider this a dangerous situation, and a possible fire hazard.
Thanks for using FixYa,
Hope this helps,
Eric
Dec 11, 2008 | ZT Group CISNET A7050 PC Desktop
Blue power LED flickers on and off; monitor won't turn on
call 1800 samsung and it s cover under warranty untill may 2009 and thye will send a replacment free to you 7-14 days toa ups store near you all you do is walk in and exchange it
Nov 28, 2008 | Samsung SyncMaster 931B 19" LCD Monitor
Problem in monitor 793s (no high tension,power led is belinking,hearing a sound like contact relay (on then off)
Time for a replacement, CRT monitors are not in the realm of repair, just replacing. You could get a good deal on a used one as these monitors are becoming obselete!
Oct 25, 2007 | Samsung 793S 17" CRT Monitor
MPC Computers AOC 7F 17" CRT Monitor Logo
100 people viewed this question
Top MPC Computers Computers & Internet Experts
Paul Bade
Muggs01
Muggs01
Mark Gough
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
