Question about LG WM-1832C Front Load Washer
Gasket around the door
The gasket on the bottom of the door tore off and now the machine is leaking. Where can we find a replacement part? My husband is very handy so he may be able to fix it. Thanks, Katie
  • Anonymous Feb 15, 2008
    door has small tear but was not leaking. Now door is leaking from the middle front. It is also pretty noisey. We have tightened the hardware on the door frame.
  • Viego Feb 17, 2008
    The rubber "bladder"/ gasket of mine has become in 4 different places and is consequently leaking. How easy is this to replace and where can I purchase one? Thanks!
HAVE NEW DOOR GASKET, HOW DO YOU GET FRONT OF MACHINE OFF?
Posted on Feb 27, 2008
6ya staff
SOURCE:
Ways leak from the bottom when you start the wash
this may be something stuck in the gasket(rubber) that seals the door. Fold down the gasket all thew way around the gasket, remove any thing hat may be there. This could be coins, small articles of clothing, or a wash cloth.
If no obstruction is found, it probrbly require replacement of the door gasket/seal.
Mar 27, 2011 | Kenmore Elite 45986 Front Load Washer
Water leaking out from bottom of door during operation
clean the glass real good,, if it still leaks take a hair dryer to the part of the gasket that seals around the door,, heat it while pulling the lip out toward you ( not much just try to get it straight) if the doesnt work you will need to replace your gasket,, also know as the bellows
Jan 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Leaks under door
IF LEAK IS FROM AROUND SIDES OR TOP OF DOOR, IT COULD BE THE DOOR GASKET, FIRST MAKE SURE THAT THE DOOR IS NOT MAKING CONTACT ON THE SIDES WITH CABINETS, THEN CHECK THAT THE SPRAY ARM ROTATES FREELY INSIDE AND NOT SPRAYING DIRECTLY ON EDGE OF DOOR. THE GASKETS ARE REPLACEABLE. IF LEAK IS COMING FROM BOTTOM OF DOOR THEN THE PIECE IS CALLED A BAFFLE AND IS ALSO REPLACEABLE. MOSTLY THE PROBLEM IS OTHER THAT DOOR GASKET OR BAFFLE. THE DOOR DOES NOT CLOSE COMPLETELY WHEN CONTACTING THE CABINETS.
Mar 10, 2010 | Whirlpool Dishwashers
Leak around bottom door gasket
No, you don't need to remove the door to replace the gasket. It is usually a pressure fit and will just push into the alloted space. Take notice of where the originial one begins and ends before removing it.
Nov 18, 2009 | Frigidaire Dishwashers
The gasket has cracked on the bottom and leaks. I have bought the new door/drum gasket. Where can I find instructions as to how to replace this large gasket/ring that stops water from leaking out the door
This is not to my credit, but I found it on Fix-it--
here is an online manual ,as txt url wraps around you may have to copy paste it .
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer, Front load #WCVH6260 F W W - trying to
use a theromstat screwdriver,
ver small flat head, push it betwen the detent
and the clamp it should release right away
Oct 03, 2009 | General Electric WSSH300G Front Load...
Bottom of door leaks
On almost all dishwashers, the gasket runs around the entire door surface (normally on the dishwasher, not the door itself. It is the shape of a rectangle and near the same size as the door.
A failed gasket is the most common cause of leaking.
Replacing it is not as hard as it appears but each one is kinda different.
Aug 17, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM-1832C Front Load Washer Logo
115 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
