Question about Aprilaire 550 Humidifier
Constant water flow
Even with the humidastat off I have a constant flow of water. What could be the most likely reason and how do I trouble shoot it ?
  • turnerpad Mar 08, 2008
    I have the Aprilaire 550. I just installed it. I ran the 24 volt transformer off of a 110 volt line which is not tied in directly to the furnace line. I made sure the common lead on the blower motor was pulling at least 4 amps (mine was pulling 5).
    The water continues to run when the furnace is not running. Any help would be appreciated!
  • SgtBill Apr 17, 2008
    Constant waterflow draining into furnace
I have the same problem with a Aprilaire 760. I'm guessing it's a bad solenoid but want to hear that from someone who can confirm this.
Posted on Feb 23, 2008
The night light turns on, nothing else works.
check the humidastat, its the setting on how much humidity you want . your supposed to turn on to high speed for a couple of minutes and then switch to low to keep filter wet. the humidity level will affect the on and off operation. other than that test the plug with another appliance such as a lamp to see if plug is good, the night light will work for awhile without power for some reason.
Apr 01, 2011 | Hunter Care-Free Plus 34352 Humidifier
I have a whole house Honeywell E365 humidifier which is constantly flowing water to the pad, even when the heat is not on. What could be the cause ?
Hello, the most common reason this happens is because the solenoid valve is bad and remains open allowing water to flow continously regardless if the furnace is on or off. I assume you have either a sail switch or current sensing relay energizing the humidifier when the heat is on, if not thats another reason it would run continously.
Jan 24, 2011 | Honeywell HE365 Humidifier
What is the purpose of the sailswitch
The sail switch is in the cold air return it is wired in with the humidastat when your furnace goes on the air movement pushs the sail down inside the duct work that makes a contact the lets the 24volts to the humidastat. If the humidastat calls for moisture it turns on the humidifier but only when the blower on the furnace is on So in short it detects air movement
Oct 03, 2010 | Honeywell HE360A1027 Whole House...
Water keeps flowing through my humidifier even when the furnace is not on. Consequently my water bill is quite high. How do I take care of this problem of the water continuously flowing through the unit?
There should be a solinoid valve that starts and stops the flow of the water, based upon a call for heat, and to ensure the fan is running during operation. There must be some failure with this valve, or a short in the connection causing it to run constantly. Hope this helps
Mar 19, 2010 | Humidifiers
Water flow from humidifier never stops. Even when furnace is off.
No, it will not stop flowwing if it is the water supply. A solenoid valve opens the flow everytime there is a call for humidity, but it stops at the humidifier when there is no call, so it will leak from that point until it is fixed or tightened.
Apr 17, 2009 | Honeywell HE365 Humidifier
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
Aprilaire #224 celinoid not opening, water not flowing
it may be kickin on but you dont get water there is an metering device {little piece of plastic with hole} that cuts down on waste water it may be clogged to see if it is opening take a screwdriver and see if when humidastat is trying to work that you have a slight magnetic pull on the opposite end where water lines go
Feb 05, 2009 | Aprilaire 600 Humidifier
Aprilaire 760 humidifier. no power to humidastat
the 760 send power out the humidistat is just a switch if you touch the two brown wire coming outof the 760 the humidifier should come on if it doesnt and you had appiled power to those wire you probably shorted the 760 control board
Jan 15, 2009 | Aprilaire Humidifiers
Aprilaire 550 humidfier not getting water
Is there 24 volts coming from the humidastat to the solinoid?
Dec 07, 2008 | Aprilaire 600 Humidifier
Water flow through humidifier
I installed this humidifier (and had a lot of trouble installing it!) and was surprised by the flow of water. Mine leaks out of the bottom of the unit so I haven't actually used it yet. I'll try to figure out why it's leaking this weekend. I thought there would be less water flowing through the pad. I suspect that the weight of the unit is causing it to not be plumb so some water is dripping off of the pad and past the drain tray.
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Aprilaire 550 Humidifier Logo
183 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
