Watches Logo
Posted on Dec 30, 2009
The 24hr hand is meant to keep time in another
We bought the Invicta model number 6089 and we set the second hand for the time in England which was 6 hours ahead but whilst still in mexico the second hand started to lose time and instead of showing 6 hours difference it only showed roughly 2 hours. We tried to change the watch at the shop at the airport but they would not help. Now in England the second hand is still not showing the correct time. Can you please advise?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
404
Points
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
The second hand won't tick
On many Invicta watches, the large hand which points towards 12 o'clock is not a second hand. It is the hand used with the stopwatch function. If yours is a chronograph, the second hand, if there is one, may be one of the three small dials on the watch face. There are a number of movements used in Invicta watches and the operating instructions can differ from movement to movement. The battery also will be different depending on the movement.
The seconds hand on my invicta subaqua reserve does not move. It only moves when I start the chronograph. I've read the instructions time after time and can not get it to work.
The hand that moves when the chronograph is working is not a second hand. It will rest at the 12 o'clock position unless you are using the stopwatch. If your Invicta has a second hand, it is one of those small dials on the watch face.
I bought a invicta watch model number 6620 and i dont know how to change the day setting. It reads wed but i need it to be sat.
The Instructions for Invicta watches can be found here:
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
the instructions are organized by the functions of your watch , not by model number. Refer to page 6 of the pdf file to find the instructions for your model.
Mar 26, 2011 • Watches
I have a new invicta watch model number 6089 that I just recived yesterday. I can set the time and date but for some reason I can not set the 3 arm?? I have read the instructions and still it will not...
The trick to setting the 24hr hand on the 6089 is to pull the crown out only one notch (not two) before using the upper push button to change the time. As it's a 24hr hand, the best time to set it is at the top of the hour.
3helpful
I just purchased an Invicta Sea Wizard Chronograph Watch, and after taking it out of the box I noticed the large second hand does not move. The watch seems to keep time, but the scond hand is frozen in...
The large second hand is actually the GMT hand for a second time zone. The second hand is the small sub dial at the 2 o'clock position. The large hand with the red arrow is the alarm time.
1helpful
Have an Invicta Lefty Quartz Chronograph. The subdial that marks the minutes fails to reset to 60, though the large second-hand resets perfectly. Recently I bought another Lefty and had the same problem. I...
Actually the sweep arm can be set to 0 and will probably have to be every time you have the battery replaced. To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it. Make sure to set the right time and replace the crown in the time position.
Great watch!!
4helpful
2answers
Invicta Speedway 9223 not keeping time
It sounds to me as it is a quartz chronograph and it is right that the centre seconds hand moves only if the pushbutton is pressed. If you look close enough, you will notice that the small subdial finger is ticking and counting seconds. It is recommended to replace battery, as sometimes watches been laying in stores for a few years before selling and the battery is flat or underpowered.
Want to know more about your watch? Go to www.invictawatches.com and find out.
Regards
Arthur
Top Invicta Watches Experts
Ngoro
john h
Are you an Invicta Watch Expert? Answer questions, earn points and help others
