Cpu not starting after power outage
My computer was on and working fine then we had a power outage, and now it won't start up at all. my wife's comp is fine but mine does nothing
  • brew1971 Jan 30, 2008
    thank you, is it hard to change or expensive??
    Genius:
  • 1,067 Answers
Need new power suplly that one got shot and make sure your on hi end protecter never on wall ok
Posted on Jan 30, 2008
  • nick helpap
    nick helpap Jan 30, 2008
    no not hard at all to do they sell nice one atx style at store 40 bucks antec ect circuit city nice least 400 watts one and plug intoa nice monster cable breaker power strip last forever then 4 screws on back 20 or 24 pin connection to mobo rest is 4 pin plugs cd rom hard drive ect easy
  • nick helpap
    make sure u plugs back in new one 12v 4 pin with main borad 20 pin then rest easy 4 pin molex plugs cd roms
My sister year old GE dishwasher won’t start. Ha don’t a power outage and after power came on she tried to start it and wouldn’t work.
If it was running when the power outage happened, that may have "fried" the control panel.
She needs to have it checked by an appliance repair person to see if that is so.
God bless your efforts.
Jul 02, 2018 | GE Dishwashers
Power light flashes but PC will not boot up following power outage
First off: Protection is important and the ONLY way to go is with a UPS (Battery backup protector). These devices allow the computer to SLOWLEY close down and protect the motherboard and hard drives. Simple bar protectors are of little to no use whatsoever. As for the Start UP; the Boot Sector on the Hard Drive has been compromised. If you attempted to start with the F8 key when you started up the computer and failed to Boot in the Safe Mode, you definitely lost the operating system.
You can try to do a Restore, but that may not be effective.
When a Computer starts, there is usually a Beep (called a Post) and one Beep indicates the motherboard is active. Several beeps indicate a mal-function of the motherboard and it was damaged. In some cases, the Memory (RAM) can be damaged from electrical surge, and thus the computer will not start and the monitor will not be active. Do not touch the internal leads as they are not the problem. In closing, a CPU is very sensitive to power surge and the CPU in some cases can be defective. All in all, with so may options or repair issues; only a professional has the equipment to search for the solution. Good luck: DaytonComputerDoctor@hotmail.com
Dec 18, 2013 | Evesham Axis 64 3000+ (AXIS643000+MAR04)...
My computer monitar not start when i start cpu......why..????
The Port you hooked it up to isn't active. If you have another video out on your comp try it and see. Are you using a laptop or a desktop comp?
Oct 27, 2013 | Samsung SyncMaster Computers & Internet
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
My comp does not show anything on the moniter??
If you have another monitor try it, if it works then you have a bad monitor. If a different monitor doesn't work in it then it could be the motherboard or CPU. If they are bad there is not test for that, the only real way to test them is to buy one piece at a time and see which one works. Also if your monitor has a power adapter check it. Sometimes those do die and not the monitor.
Feb 26, 2009 | HP Pavilion (PN153AAR) PC Desktop
Blue error screen when starting up computer
looks like a OS software problem on reboot try pressing F8 and choose last good known configuration
if that fails to do the trick
This option will put your comp back to how it was when you bought is so all you saved stuff will be lost
press contrl and F12 together on boot up this will restart pc as it was when bought new
Aug 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No Green
Check the crt board and follow the green signal path, could have a shorted transistor or a resistor out of tolerance on that line, check all the components on that line
Nov 01, 2006 | LaCie Electron 19" CRT Monitor
Computers & Internet Logo
63 people viewed this question
Alun Cox
David Payne
David Payne
