If your netbook has an external VGA port (blue 9-pin connector) you may use the integrated dual display/extended/or external features of your netbook using the necVT460 VGA port. The resolution max supported is 800x600, so make sure you setup ur display at this resolution before attempting to extend the video signal.
I used to use a Ryobi 2.5 hp and it worked fine but if you are concerned go higher hp. It's probably more important that the router is a variable speed model. The bigger the size of cutter required for raised panel doors the more torque and revs are produced. You need to ensure starting on slowest speed and adjust up to speed required. Speed should be based on size of cutter and to me is set by sound( a nice hum, not screaming) and vibration( NO VIBRATION)! The cut needs to be done in several passes, maintaining constant feed speed,( don't burn your expensive cutter) allowing cutter and machine to do work maintaining the hum and no vibration. And of course set your guards etc!! If this is on going work for you perhaps look into a spindle moulder with attachment to take router cutters
What OS are you using? Win 7? Is the Printer and the netbook on the same network? Setup the Printer on the Access Point/wireless device that the Netbook is connected to, make discoverable, turn on wireless, on the Netbook, Start menu, Open Devices and Printers, click on Add a Printer, All a Network, Wireless printer, follow the setup. Take a look at this vid: http://www.youtube.com/watch?v=ogUtDfaB5ms
Kindly refer on the link I have for you below where you can download the sound driver for your HP Pavilion 520k. Just make sure to select the operating for your PC. Once you're done downloading the driver, install it. You're system will prompt you to restart once installation is finish so make sure to restart.
