Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Scanning - error: Sender's name not selected
Ricoh Aficio 1515MF
We have a few of these machines in our company, but this one won't let me send a scan to an email... above error message.
  • 2 more comments
  • Anonymous Apr 04, 2008
    Where are the protection settings located?
  • office_equip Oct 10, 2008
    I have nothing listed as "Protection Settings" under an address book entry. The documentation provided by Ricoh is worthless. Where exactly are these "Protection Settings" where we are supposed to set the e-mail address?
  • lilbrem
    lilbrem Dec 04, 2012
    agreed...no protection settings
  • OfficeServiceAjnc
    OfficeServiceAjnc Jun 26, 2018
    in system setting under file transfer you need to turn on auto sender name apply. if you need exactly point to point where to turn it on please leave a comment
Finally figured this out!!
Go to: UserTools - System Settings - File Transfer Tab - page 3 of 3 - Auto-Specify Sender Name - <ON>
Posted on Jan 28, 2009
First, you are going to need a lot of patience and about an hour. Forget about the idea that this is going to be simple. This is a Ricoh printer. You are going to have to peck at a little touch screen until you are exhausted. The menu you need is nested 20 deep. You will need to enter your email address on a tiny touch screen keyboard about five times. Forget about doing it from the scanner screen. You have to administer the address book. I am not going to tell you exactly what you have to do, because I don't have an hour to find the screen I was on again. But here is my vague recollection. There is a little button above and to the left of the touch screen. It says user tools or something. Push it. You will see some buttons on the screen. Ignore the one that says scanner. Try the one that says something like system tools. Now you will see a bunch of tabs across the top. Choose the one that says something about system administration. Now you will have a multi-page screen. I think you need to page down to page 2. Look for a button that says administer the address book. I forget what to do next, but basically you are trying to enter yourself into the address book. You will see a bunch of tabs across the bottom. You need to enter your email address on more than one of the tabs. Also, someone mentioned going into the protection tab and setting it to both destination and sender, or something, so do that, too. If you have managed to enter yourself in the address book correctly, which you probably haven't on the first try, then start hitting the exit button until you are exhausted. If you get all the way back out, then you can hit the scanner button to the left of the screen. You should see your email address in the freq list. If not, then repeat the above steps (good luck). If so, select your email address. Now put your document in the paper feeder and click the big green start button. This is my favorit part. You will now get the original error message again. Don't panic. Find a ball peen hammer. Hold it firmly above the top right corner of the touch screen. Don't drop it yet. You will notice that a new button is lit up that says select sender. Push it with your finger. Discard the hammer. Now find your email address again in the freq list. Select it. Now press the green start button again. This should send the document to your email address. If not, find hammer again and excersise your best judgement and debugging skills.
Posted on Mar 19, 2010
  • 87 Answers
Open the address book. Under the protection setting, select both destination and sender.
Posted on Feb 23, 2008
Login on the machines web interface.
Fill in the adrress book correct!!
User name has to be a destination and a senderaswell.
Than you have an option to attach a sender when you want to send an e-mail.
Posted on Feb 26, 2009
  • Arnaldo Carvalho May 02, 2014
    tech exp is correct! All digital copiers scan the original and send it to laser buffer, to make a copy. Scanning to computer is the same process, only the PATH is different. Show the path to copier and it will perform the task well. The machine is ok, only the data is incorrect or faulty.
    Problem Solver:
  • 5 Answers
User's tools then address book then select the protection it must be sender.
Posted on Feb 16, 2009
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Try this
Follow this steps
User Tools ------>>>>
System Settings---------->>>
File Transfer Tab------------->>>>
Go to last page >>>>>>
Auto-Specify Sender Name Should be on.
try it
this will work
Posted on Jan 07, 2015
    New Friend:
In 2020D (very old model) you can do it only with panel printer interface, in menu scanning settings, auto set sender email to printer admin.
Posted on Sep 15, 2014
SOURCE:
Clear memory
This page of the manual seems to discuss the problem:
http://www.manualslib.com/manual/314275/Ricoh-Aficio-1515.html?page=46
May 09, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
I am trying to setup the 1515MF for network scanning. The manual tells me to go to scanner and select Twain on. But when I go to scanner features and then scan settings, my only choice is "default...
First download the twain drivers from Ricoh website or if you have cd down load it from it. Then from there when you go to scan should give you selection option for it.
Jan 05, 2018 | Ricoh Aficio 1515MF All-In-One Laser...
Necesito los drivers para la impresora Ricoh Aficio 1515MF
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/x15_15f/x15_15fen.htm
Mar 05, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
How to reboot the ricoh aficio 1515mf. i could not use as all were password protected. how to erase all the password and memory??
To clear the memory (reboot) the RICOH AFICIO you will have to send it to the factory where they will wipe the memory and restore the machine to its defaults.
Nov 10, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 1515mf SC 121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Apr 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Service call sc:543 for Ricoh Aficio 1515mf
plz do like this after again it shwos same then need to replace parts thermister,and thermal fuses. press the yellow 107 red and hold the red for two mints it shows copy sp.......like switch off on
Mar 25, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
19,088 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
