Question about OKI OL 400e Led Printer
OL 400e Led printer
I have had this printer for about 13? yrears. It has had some periods where it was not used at all. In trying to use it now, I can print one sheet and then get a paper jam error. There is no paper jam but the printer is not picking up a sheet of paper and feeding it. Usually I open and close the printer and can print one sheet (sometimes not) and get the same error. Very frustrating. Any solution? Thanks.
  • ccal4 Jan 30, 2008
    Just thought I would get a little more specific help rather than whole service manual.
    Genius:
  • 1,067 Answers
Paper jam usally meen on your model exit is not working properley and u have to buy a new paper exit jam tricky to get pars fo rthese old ones bestto upgrade nice lexmark 30 bucks all in one at wallmart on sale
Posted on Jan 30, 2008
  • nick helpap
    nick helpap Jan 30, 2008
    cool guy he dont know what hes doing most of time
  • 1,512 Answers
The machine will need a clean and service. This job can be attempted by yourself... you just need to get access to the bits that need cleaning. This means anything that comes into contact with the papaer to carry it through the printer. You will need to clean paper dust and residue of the paper feed rollers. Do this with Iso Alcohol, a lint free cloth and cotton buds. These rollers are rubber material and should feel "grippy". Also check that there are no fragments of paper in the feed assly.
    Genius:
  • 3,422 Answers
Here is the service manual for it.Go through it once u'll find ur solution.
Download it frm here
Goodluck,
Dont forget to rate me as fixya..
  • Priya darshan Jan 30, 2008
    1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
    2. Menu window will show "OKI USER"
    3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
    4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
    5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
    6. Window shows "NV-Ram- Initial Table 1".
    7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
    8. Restart printer.
    All toner, drum, fuser and transfer figures return to 100%.
Where is a 1992 Mercedes 400e ecu located
Mating ECU to Throttle Actuator 1992 400e - PeachParts Mercedes ...
www.peachparts.com > ... > Tech Help
Jan 1, 2007 - How does one mate the ECU to the throttle actuator on a 1992 400e. I read the manual and I ... Join Date: Feb 2005. Location: Cleveland, Ohio. 400E performance upgrades
Nov 19, 2009
1992 400E auxiliar fan control
May 26, 2007
1992 400E aux water pump location?
Mar 27, 2004
More results from www.peachparts.com
1995 Mercedes-Benz E420 0-60 with 400E ECU - YouTube
? 0:10
https://www.youtube.com/watch?v=gpGOm_sO-lM
Feb 14, 2013 - Uploaded by vGEMATRIAv
I just plugged in the new 400E ECU and am testing it. Sure the difference is subtle--even not noticeable, but I ...
Jan 23, 2016 | Cars & Trucks
Unit periodically shuts off. LED flashes "13."
it sounds like a dirty flame sencer rub down with emrycloth or fine wool steel if that dosent work need new pilot assembly.
Jan 21, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Dear Sir(s) I have an OKI data OL400e the problem is "Message --Cover open" even i close it well Please advice Thanks
had the same problem. It is easily fixed.
On my printer a OKI C5750 is had to main covers, at the front (which you have to open to fix a paper jam) and a big cover on top (which you need to open to replace toners).
On the left is a piece of plastic which (when closed) presses on a switch.
When you open both covers, and close the top one, you can see it on the left when it comes down.
You can easily remove the error (only for a brief moment) by prushing the shining metal switch to the back.
But the problem is that one of the rollers is in a wrong position.
So just take a flat screwdriver and press on the bottom roller, and it will click and the problem will be gone when you close the covers.
Feb 11, 2010 | OKI OL 400e Led Printer
Dark lines appear on each page I print on the printer. I have cleaned every roller, dumped the old toner and added new toner.
Are the lines vertical or horizontal?
vertical lines can be caused by several things.
Since you said that cleaned the rollers, then here are other options
1: Most common is a bad toner cartridge.
2: try cleaning the fuser entrance guide.
3: could be a defective formatter - formatter replacement the fix.
4: worn fuser. fuser replacement is the fix.
horizontal lines are probably repetitive down the page, and are usually caused by a defective toner cartridge or fuser assembly. occasionaly a transfer roller will cause it as well.
Toner loves to get baked onto the fuser and cause all kinds of print problems. Not much you can do but to replace the fuser when this happens.
Oct 17, 2009 | OKI OL 400e Led Printer
Does anyone know the pin layout for the front panel connector for a EX65-II? (i.e. the UX4SG-1394-II motherboard)
Here is pinout. Pin2 key is missing pin
1 reset+
3 reset- (gnd)
5 pwr led+
7 pwr led- (gnd)
9 n/c
11 n/c
13 n/c (gnd)
15 n/c
17 n/c
19 n/c
2 key (missing pin)
4 pwr sw +
6 pwr sw -
8 hdd led+
10 hdd led-
12 n/c
14 n/c (gnd)
16 n/c
18 n/c
20 n/c (+5v)
n/c = no connection
Aug 03, 2009 | AOpen EZ65 (ez65white) Barebone
Documents come out wrinkled
problem with fusing assy. replace fuser.
Jan 15, 2009 | OKI OL 400e Led Printer
Canon imagerunner 400e
If the copier needs to be up-dated. It can only be done by a tech that has a laptop. The copier needs to be "Flashed" or you need to run the setup again.
Feb 22, 2008 | Canon imageRUNNER 400S Copier
There is a serial port besides the parallel. how can i make it work with serial cable?
if the printer is built with a usb port, the it should work, is there another USB device in the PC that is working ?
Jun 02, 2007 | OKI OL 400e Led Printer
OKI OL 400e Led Printer Logo
193 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
