The best way to download videos (and pictures) from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos (and pictures) from the card to the computer's hard drive, the same way you copy any other files. Or you can use any video/photo cataloging program.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program. Just do a Google search for "photo catalog software."
You might want to consider NOT connecting your camera to the computer.
Windows XP uses its own built-in drivers for digital cameras like your Optio 50. There is not driver for you to download.
With XP you should be able to simply open up the "My Computer" icon on your desktop.
Under "My Computer" you should see a "Removable Disk".
Double Click on it, and then your should see "DCIM", double click on that and then you will see "100PENTX".
Double click on "100PENTX" and you will see all your pictures.
You can then copy those pictures to anywhere on your computer.
If this does not work for you, you can always use a card reader to
download your pictures. Many later model computers have built-in SD
card readers. If your computer does not have a slot for an SD card you
can purchase a card reader, usually for under $20, at most major
computer/electronics equipment retailers.
I also had this problem. I think it is caused when the camera is turned off while in the viewing part of the camera. That is, I had gone to look at the video that I had just taken, but didn't and then turned the camera off. The camera is then as you have described it.
The only way I could get it back to normal is to connect the camera to the computer, using the cable, and download the photos and videos. When the download is complete, disconnect the camera and it should be OK.
Good luck, cheers. Phil
