Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
56" can you tell me how to fix it
    Genius:
  • 1,030 Answers
What is wrong with it
Posted on Feb 22, 2008
The control panal on freezer door says 56-56 will not despence water or ice
Good Afternoon Friend,
I understand that you are receiving a 56 56 code on the display of your Frigidaire refrigerator, model# GLHS269ZDB. I also see that it is not dispensing ice or water, even though you have reset it by unplugging it. The 56 56 is actually SB SB. This tells me that your refrigerator is in Sabbath mode. To exit the Sabbath mode, press and hold the down arrow and the plus sign, simultaneously for 5-10 seconds or until the display changes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Turned on new heater last night, according to instructions. It was on high all night and never got above 56 degrees.
We need a little more information:
When you say 'never got about 56 degrees'--
are you saying the heater never got about 56 degrees?-
or the room it was in, did not get above 56 degrees?
Can you hold your hand on the heater?-- is it hot, or is only lukewarm?
Are the indicator lights on the heater indicating that you have power, and the heater is working? (Or trying to heat the room, at least?)
What other sources of heat do you have for the room-- and how cold is it outside?
Tell us more--
Mack B
Jan 10, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge : My Executive 56 spa pump (1-l/2 years old) is leak...
Thank you for posting your question here on Fixya.com.
There is a seal in there that a local pump repair shop can fix for about $30 - $50 with parts and labor. Waterway pumps use a 1000 seal that is not a seal the homeowner is usually successful at replacing themselves.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 18, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
I received the following trouble codes on my 1997 Dodge Ram 1500 with the 5.9 liter engine: 12, 31, 56 I assuime 12 is a toss away... I don't understand the description for 31 and I cannot locate 56 in my...
code 31 is the evap system, the fumes from the tank, the computer can seal or vent the vapors, and so its telling you theres a big leak its not able to seal, could be a loose or bad gas cap or a broken vacuum line for the system or a vent or purge valve went bad,code 56 is not a code, double check . good luck,hope this is helpful.
Dec 19, 2009 | 1997 Dodge Ram 1500 Club Cab
Red convergence will not line up on my jvc 56 inch i art projection tv model # AV-56WP74. PLEASE TELL ME WHERE CAN I BUY THE KIT SO I CAN FIX IT MYSELF!!!
You need to pull the front grill cover/panel off the front of the tv. Remove screws (4) from back that hold it on, also 2 small ones behind front video input door. Then remove access panel. The ckt board closest to you is the convergence amplifier board. You should replace both amplifiers (stk392-110 or 120) and any burnt/open resistors you find near the amps.(use the same value resistors as the corresponding resistors in the blue amp ckt)
Jul 08, 2009 | JVC AV-56WP30 56" Rear Projection...
Google Talk Error 56
Error 56, it is always related to a time and synch issue.
Synch the Blackberry time, and the network time to solve the problem.
Once you synch the time the error will go.
Go to optionsmenu, then date/time. There you make sure that the settings are :
1. Set to the right time zone.
2. Have correct date and time.
3. Set date/time source to Network.
That will fix the E 56 problem.
Dec 01, 2008 | Google Talk
Proscan PS56670 56" rear projection TV
For a 10 years old TV, it might not be worth fixing it. Save your money to get a new one once this one gives up.
I would keep it running using with the back cover off using that fan to keep it cool.
Hope this helps.
Apr 29, 2008 | Proscan PS56670 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
19 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
