Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Tv picture Havin 50 inch projection tv with a pink and a blue hue to it happened suddenlyg problems with Sony
    President:
  • 4,402 Answers
Http://esupport.sony.com/perl/news-item.pl?news_id=24
and try this
Sony Picture tube recall
http://esupport.sony.com/perl/news-item.pl?news_id=24
Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
Posted on Feb 04, 2008
Problem with sony 60" rear projection TV
I'm afraid, it is problem of optical block unit (light engine) that produce picture by 3 lcds inbuilt, the blue lcd and its related uv filters become defective and causing this kind of blue hue on screen.
Complete optical unit block (light engine) will be replaced by qualified tech to get tv fixed, light engine is costly part so ask an estimate before sending tv in.
Thanks.
May 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue hue on sony hd-tv
you need to replace the optical block sony had a recall on this part though I believe it is over contact sony tech support to see if they can help with getting it fixed part is quite expensive
Jan 24, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I have a blue line problem with 50 inch sony wega.
Take to TV repair shop. contact Sony get RMA first for warrenty work! so free work gets done!
Oct 09, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KP-53HS30 started with Pink and Blue picture and timer blink
You probably have one or more bad CRT's causing the problem. Due to the age of the set and cost of repair, I would not invest the money needed to repair the set properly. I would replace all three CRT's and the cost would run over 1000.00 up to 1300.00 .
With the cost of new sets today, you could replace it.
I hope this helps,
Skyassoc
Aug 05, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony Rear Projection TV - Red tube too strong
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
May 16, 2008 | Sony KP-57WS500 57" Rear Projection...
Pink Hue
it must be the problem of convergence in the tv.
for pictures on where is the convergence settings click on this given link.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
but if its the problem in convergence board then check out for this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
May 04, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Color convergance
The green hue (I had it too) is a result of the optical block failing.
Sony has extended their warranty (regardless of the purchase date). see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR60XBR1&news_id=185
Apr 24, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
178 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
