Question about 2wire 2700HG-B Router (2700HGB)
Cant make the wireless work
I previously had regular DSL modem, but bought the 2wire 2701. It's hooked up properly, but can't configure the wireless part.
  • 24 Answers
The wireless has to be turned on in the HG2701. See:http://www.2wire.com/pages/pdfs/5100-000326-000.Rev.A.pdf for details on how to do this.
Hope this helps!
Posted on Jan 31, 2008
How to configure 2wire 2701?
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
if you are with At&T AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 11, 2011 | 2wire (2701HG-B) Wireless Router
Can't access modem from desktop
If your DSL works on PPPOE then you need to setup PPPOE on the 2wire router with the Complete Username and the PAssword for the PPPOW connection, if your DSL works on a Local IP address like 192.168.1.254 or 192.168.1.1 then first check the gateway address of the 2wire Router, if it's in the same IP address range like the DSL Modem like 192.168.1.x the you need to change the Local IP address of the router from 192.168.1.x to 192.168.2.x that should get you up and running with the DSL Modem.
Mar 25, 2010 | 2wire 2700HG-B Router (2700HGB)
Is the DWL-520 Wireless Adapter compatible with the 2701 HG modem
The 802.11b and 802.11g Wi-Fi networking standards are generally compatible. An 802.11b router / access point will work with 802.11g network adapters and vice versa.
There is no such conflict reported with the above devices. But as suggestion use an 802.11g wireless card with the Bell as it would give you better performance
Thanks for using Fixya
proton
Jul 27, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Jan 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting DSL/Router to DIR-628 internet router.
it is possible but the routers have to be on separate channels
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
Att 2701 hg-b modem
Hi , the 2701HG-B by default uses the last 3digits of the SN number as the SSID and the 10 digit number in brackets as the WEP key to access the user interface of the 2701 type in the address bar of your browser 192.168.1.254 and push enter, to access the interface program you will need to run the system set up and you must know the keycode from your service provider and the username and password
Jan 06, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2wire 2700HG-B Router (2700HGB) Logo
106 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
