Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
56"wide screen it has an arc on top and bottom making everything blurry
  • plumberbobo Jan 30, 2008
    why didnt you guys say i had to pay for the answer in the first place and i would not have waisted my time
  • anachoo Feb 13, 2008
    it has an arc on too...colors are blurry and doubled
Have you tried to adjust the convergence? If you can't get them to line up then you may need to replace the ICs.
Posted on Feb 11, 2008
6ya staff
SOURCE:
I got a Zenith Z56DC1D the bulb was replaced and its clean. I have blurry picture and it seems out of alignment there is a large black stripe on bottom and the top of the picture is cut off. How do I fix...
Without seeing a photo it sounds like the picture is letterbox with top and bottom black areas---if not that it sounds like a possible issue with the optical light engine the set uses to project the image on to the screen----most of this is not customer repairable.
Dec 04, 2012 | Zenith Z56DC1D 56" Television
I have changed bulbs but still have a blurry line
the light tunnel is collapsing and needs replacing. the part is cheap.
Aug 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Arcs at the Top and Bottom of the screen!
You will find small 1/2 or 1watt resistors close to the ic's, you must measure them and they must be exact ohms. I believe you'll find a couple open or have changed in value, I hope the new Ic's haven't been fatigued. That should fix your problem.
Jan 19, 2009 | Philips 60PP9202 60" Rear Projection...
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Green color convergence
make sure you hooked everything up properly and that all connections are tight
Aug 26, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
How can I fix my 56" widescreen jvc
ok. let start this process. are the colors seperated? RED GREEN BLUE Then this is suspect will be a convegence problem. which 85 percent of the time is what is know as convergence ic chip failure. a electronic part replacment. are you a tech or know how to solder. any experince would be helpful but i would have to admit this really is not a job for non techs there are setup issues. at our shop the cost of such a repair averag 135 to 250
Jan 29, 2008 | JVC AV-56WP74 56" Rear Projection...
1/2 the screen is blurry
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Toshiba 53HX71 53" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
