Admiral washer won't spin water out,,, ''except'' on delicate cycle.(the clothes are still real wet. especially jeans)... clock on timer still working. Started not spinning on the regular cycle (wash& rinse) and then (a few days later) wouldn't spin (wash & rinse) on the perm press cycle. Do I need a new timer, a motor (it's a 2-speed motor, 22lb capacity), parts for the motor, a capacitor???? Need help? What part do I need? P L E A S E !! ??
are you sure that its spinning as this is a common problem with wet clothes. When the cycle is complete the clothes should be wrapped around the bottom of tub not just lying there,
No you need to check ur clutch, u can check it by running the spin cycle for a few minutes then shut it off and turn machine up so u can look under it. get a spray bottle with cold water and alil soap detergent, then spray the clutch with it, if it shows or steams up or sizzles then the clutch is slipping and bad. the cluth is in the center near the tranny, should look like a round siver pc of metal about 5 inches in diameter
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Maytag washer parts, GE washer parts, and other brand names on the market are all designed to work interdependently with each other. This system starts to break down if even one part begins to encounter difficulty. Your washer's spin cycle flings a large amount of water out of the clothes, but if the water can't drain, the clothes will soak it all back up, defeating the purpose of the cycle. Excessively wet clothes after the spin cycle may not be caused by faulty washer parts, but rather a blocked drain is a very good bet. Check the drain line for a blockage and try again. If your hose is kinked or bent, this can also cause a drainage problem. The failure of one simple part creates a larger problem for all the washer parts. What can cause a blockage? A number of items; paper left in the pockets of your jeans, coins or other debris, even socks. Check your hoses, and make sure your laundry has empty pockets for future loads.
