Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony Grand Wega KDF-E50A10 showing msg about unauthorized content HDMI
From receiver to TV using component video cables everything is fine. I now have a digital cable set top box and have tried going from DVI to HDMI to the rcvr and then from the rcvr to the TV using an HDMI cable and I see a big message over the video about unauthorized source and after 10 seconds the whole screen goes to lime green. I talked to Best Buy and they said try taking the rcvr out of the loop. I did this and even replaced the set top box with one that I know works fine with another Sony TV going straight HDMI, no luck. I now have a set top box pushing HDMI to this TV and the TV is giving a slightly diff msg about the source not being authorized and that i should switch to Y P Br cables. Why cant I get HMDI to work?
  • Dricha7 Jan 30, 2008
    Sony support site hasnt been any help. Live chat with their monkey hasnt yielded a dran thing.
    Sergeant:
  • 261 Answers
Did you select the output of Cable box to HDMI out? I think it is in the menu setup on most cable boxes. It maybe active but if it isnt, try this.... Hold Menu button down and see if setup menu comes up and then toggle with arrow buttons on front of settop box and try and select HDMI if it is in there. Also make sure settings are on in the T.V. menu as well. Let me know and we will continue. Thank you ...GURU JAY
Posted on Feb 06, 2008
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
How do I fix an HDMI input that has stopped working
This sometimes happens on my Samsung tv. With the tv switched on try unplugging the tv from the mains supply and leave for 3 minutes then plug back in and try. I hope this helps.
Nov 16, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sorry for the duplicate post, but somehow someone's not helpful solution got marked as solved, so I'm going to post again. I have a Sony Wega KP-51WS520. The problem is with the HDMI port. I have...
HDCP is causing the trouble You experience. Try using other video input connection for same set. If it works fine that way, the problem is that the rights protection (HDCP) is acting as "police" to prevent copying or reproduce unauthorized content. If only the HDMI is connected (disconnect all other inputs/outputs) on some sets, could be work fine.
Oct 10, 2013 | Sony KP-51WS520 51" Rear Projection...
Sony 36 inch trinitron no picture no sound
i cannot get a signal from my HD cable box to my Sony Wega KDF-E50A10 TV's thru the HDMI cable.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KDF-E50A10 Shuts off and on every 1- 2 mintues
From what it seems in your question... the problem has already went away... However, I actually know about this. There is a fuse inside the tv near the power button called B-3a... If you replace that fuse it should help fix permanently
Dec 17, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony WEGA
If your remote has a wega gate button press that and it will allow you to add and edit the inputs.
Apr 17, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
DVD signal received in wrong aspect
PRESS SETUP GO TO MISCELLANEOUS PRESS ENTER THEN DOWN TO OSD SETUP PRESS ENTER AGAIN AND DOWN TO MONITOR AND CHANGE TO 16.9.
HOPE THIS HELPS.
CABLE GUY.
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever heard of this? Part runs about 300 bucks. TV is out of warrenty as it is 2 years old. Do you think it is worth it to fight sony and get them to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
Feb 01, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Jkae it sounds like your hdmi tuner, I had the same problem on mine and thats what it was most likely your's went out like mine.
Hope this helps good luck
Oct 30, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDF-E50A10 50 in. LCD HDTV Logo
107 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
