Question about Zenith XBR716
Change record speed for VCR without a remote
VCR automatically records on SP which does not allow me to use VHS tapes that say 3/9 Hours. How can I change this on the machine without the correct remote control?
Hope someone can help, Liza
SOURCE: VHS to DVD playback
The document for the XBR716 needs to be re-written and re-issued, because it is missing information on how to finalize the DVD.
Solution:
Press the HOME button, then go to Disc Manager.
Select the Finalize menu, Finalize and OK to start.
Posted on Jan 04, 2008
SOURCE: VHS to DVD dubbing questions
After doing all recording, go to DVD menu (use Home button on remote, then choose Disc Manager) and FINALIZE it.
This is basically a repeat of the answer above, I just wanted to emphasize it.
Thanks to this question and answer, they were very helpful to me.
Posted on May 26, 2008
SOURCE: how to record from vcr to dvd
You cannot record to a dvd, this machine is not a dvd recorder. There are plenty of resonably priced machines on the market that will record a vhs tape to dvd, but not this one.
Posted on Dec 31, 2008
RFICKES
  • 51 Answers
SOURCE: Can't copy my disney vhs tapes to dvd
I'm assuming your Disney tapes are store-bought, as opposed to recorded off the air. If that's true, the reason you can't record them to your dvd recorder is because of copy-protection. Sorry...can't advise you how to break that.
Posted on Jan 04, 2009
SOURCE: zenith xbv713 won't record on vhs tape
The Zenith XBV713 does not have a tuner and doesn't record TV shows. I think it can record if you're hooked up to cable with a tuner box.
Posted on Aug 13, 2009
How to make the VCR record for 6 hours?
With a T120 tape using SP will give 2hours of recording time, "standard play better picture and audio" to get what you desire set the speed at EP for 6hours of recording time, extended play" some remotes require you to go into menu, others have a handy button instead.
Apr 05, 2011 | Memorex MVR2031 VHS VCR
How do you change the recording speed?? with out the remote.
Soory this cannot be done without remote control although tapes already recorded in sp or lp should auto select on play
regards windyhouse
Mar 29, 2010 | Sony SLV-N88 VHS VCR
EVERYTHING YOU NEED IS IN MY LETTER BELOW.
1. On your remote, find the record mode button; it is near the bottom on the left side. This button sets
the recording speed for the DVR. Faster recording speeds provide higher quality recordings.
2. Look at the display on the front of the machine: it should say XP ( records 1 hour on the disc,)
SP ( 2 hours, ) LP ( 4 hours, ) or EP ( 6 hours. ) You can also set it to record 8 hours on a disc,
but the quality of the recording will be poor.
3 Press the record mode button until the screen displays the recording speed that you want.
4 Note: if the powers fails or the Machine is unplugged, the machine will automatically reset itself to
SP mode.
Apr 29, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Change VCR settings from SP to LP or EP
Hi;
I have a Panasonic VCR with a different, but I know how to 'fix' your problem on my m/c. The remote for my m/c has a "REC MODE" button; operating that button changes from SP to EP etc. Check it with the "Program" button on your TV screen.
harrisonmx3
Apr 27, 2009 | Panasonic Televison & Video
How to switch the tape speed on Go Video dvd/tape.
  1. Press SETUP,
  2. Toggle with the left/right arrow to the RECORDING OPTIONS (icon has a dot and the letters REC below it in the icon menus at the top of the set up screen.)
  3. While RECORDING options is selected, press the DOWN arrow to select VCR RECORD QUALITY.
  4. Press ENTER to go to the submenu.
  5. Use the ARROW UP/DOWN buttons to select the desired quality.
  6. Press ENTER to confirm selection.
  7. Press SETUP to exit the menu.
This is the same procedure for selecting the quality for the DVR recording speeds.
VHS speeds are:
SLP is 3x the recording time of SP.
DVR recording options are:
HQ=1 hour
SP=2 hours
EP=4 hours
SLP=6 hours
per disc.
Mar 18, 2009 | GoVideo VR3845 DVD Recorder/VCR
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Changing to ep
Hi, Try push (Menu) button on VCR Recorder to see Tape speed. Then follow instructions on TV to change speed of tape........Crazyred94
Jun 28, 2008 | Emerson EWV403 VHS VCR
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Toshiba M674 Lost Remote can't change tape speed
Is this an older VCR? If you can set the timer on the VCR itself
like on an older model you can set the timer and set it to record
in another speed. But if you can't do this. You are stuck at
recording in sp. If you can set the timer, if you make just
one mistake it may not come on at all. That's why vcrs
are not as reliable as dvrs. if you don't want to miss a show
diffinatly make sure you re at home and see it come on
like fill up the whole tape and put the show on the end of the tape. like a 2 hour movie comes on a 8pm-10pm set the
timer at ep speed to come on at 4:05pm- 10:05pm and put a 2 hour tape in it. in ep it will record for 6 hours. tape will stop
automatically so you will record it, and it will be on the tape
at the end. that's the way i do it. if I'm not going to be at home
if i really don't want to miss a show at all. because when you set the timer it still might not come on if you see it on you know
its going to record it.
note its cheaper to just buy a new vcr than buying a $72 remote.
you might as well do that if it is a newer model.
I bought an older model vcr in a thrift store for $10 and it worked good for a year for recording shows. I got lucky I guess.
it didn't have a remote I use the timer to set the ep speed
to record.
Nov 22, 2006 | Toshiba M674 VHS VCR
Zenith XBR716 Logo
133 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
