Question about Hobart A200 Stand Mixer
HOBART A-200 MIXER- FIRST GEAR NOT WORKING
Hi
First gear used to start spinning very fast once in a great while and now first gear doesnt work at all, motor hums. Second and third gear work.
Any ideas? Thanks
  • Birdman21 Jun 05, 2008
    Hello, What an outstanding reference site. I have the same problem with the first gear not working on my Hobart A200. I have tightened the nuts on the planetary. Found that too tight puts first into second gear. After backing them off a little, it ran in first gear speed but with little or no torque. I can feel a light ticking if I hold the gear shift lever. Is there a schematic on how to get into the transmission other than the replacement parts catalog? I have downloaded that already. I'm an excellent do-it-yourselfer, so I feel that I could fix this on my own. Can I? Also, the "grease" in the planetary is more like a dried up paste. Is this normal, or can I scrape it all out and put in fresh? What kind of grease does it take. Serial number 885074.
  • 135 Answers
Hi, your mixer was manufactured in 1947. Hobart does not make public their service manuals. It sounds like the diving key is not engaging first gear with the spinning shaft. This is the ticking sound you hear/feel. This could be because of a broken spring in the mechanism that moves this key in and out, or the key itself has become so worn that it will no longer engage the first gear. The unit needs to be opened up to remove all old grease and oil, including the planetary. The condition of the grease in your description of the planetary, is a good indicator of the condition of the grease in the trans. Your unit probably needs an overhaul due to it's advanced age and grease state. Unplug the unit. You can gently remove the two circular metal dust covers underneath the top cover. With a good flashlight you can view the overall quality of the grease and the level of it. In an ideal world the grease should fill the entire cavity and no oil should be visible. Replacement grease should be Shell Darina EP-2 or Chevron ALC EP-2. You'll need 4-14 OZ. tubes of either type to do the job. The Spec. # for your unit is 3943 Look for drawing # PL-985 Once the cover is off the trans., it's relatively easy to get to the diving key once you remove first gear (the large round gear on top). Remove what you need in sequence, and replace in sequence. If you have a digital camera, take lots of dissasembly pics. When you are done, test in all gears by turning the motor cooling fins with your fingers in the normal direction of the motor rotation. Do not plug the unit back in until you've tested all speeds manually. Good luck! ricardok45
Posted on Mar 01, 2009
  • alfredo cali
    alfredo cali Apr 14, 2015
    My first gear it's spinning but I can actually hold it with my hands and will not spindo you possibly know why I opened everything and took everything apart still not working
  • 640 Answers
Was the mixer overloaded?the clutch in 1st gear could be bad or a key is sheared.i would also check that the planetary didnt move down,this is the part where the hook/whip goes onto.you will see 2 nuts make sure there tight.im a hobart tech and very familiar with these mixers,let me know.
Posted on Feb 02, 2008
I have a Hobart a200 very old, it seems as though the spring is broken in the diving key arm, how do i get the old spring out and replace it with a new one? http://www.onesharpstore.com/catalog/item/3110109/8092234.htm
Posted on Jul 18, 2012
60 qt Hobart mixer H600T makes buzzing noise and won't spin. The hook seems blocked, can't spin it manually. Opened the top part and everything seems fine. What can it be and how to fix it? Thank you
call in an electrician as it may be the start/run capacitor for the motor ( indicated by motor humming but not running)
the gearing will make it very difficult to turn the blades by hand as the motor will be spinning at either 1400 rpms or 2400 rpms down to around 50 rpms for the blades
Jun 30, 2016 | Hobart Food Mixers
Hobart a200 first gear not working
slacken the big acorn nut away from the bottom of the planetary and then tighten the lock nut to the acorn nut. When adjusted and secured, the planetary should have a little vertical play, maybe 1/16".
That will stop the second gear driving from friction from being too tight.
Feb 27, 2014 | Hobart A200 Stand Mixer
1949 hobart a200 rebuild problem
Google Hobart --utube-ebay has 300 4sale somebody might know something--waiting on the chocolate chip cookies
Aug 02, 2017 | Food Mixers
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Kitchen aid mixer 5kpm5 motor doesnt go round freely
Any appliance with a motor should rotate freely. These are basically gear driven devices, Kitchen Aid makes different quality equipment. So either the gears are worn or possibly if you notice an electrical smell the problem could be at the tail of the motor. there are 3 major components 1. the brushes where the armature spins if you look inside the vent holes you might see a slight arc while it is running 2. the tail piece which is how the motor is kept straight. or as I said worn gears. this is especially common when companies use plastic gears instead of metal ones. Commercial appliances made by people like Hobart are expensive, but they outlast most others..
Apr 09, 2013 | KitchenAid 5kpm5eer Pro-Line Heavy Duty...
Motor not spinning in hobart 60 qt mixer
Check manually after disconnecting the motor if this is jammed. If so the motor must be reset as the bearings are faulty and so the rotor seems to get stuck with the coil core.
Also if there is high drain with heat it is possible that the coils are faulty and might need an insulation failure test.
Nov 22, 2011 | Hobart H600 Stand Mixer
Hobart A200 mixer won't start
My fantastic guy just rebuilt my A200. He says it's likely that your back plate is slightly off center so that the center arbor is touching the windings-- any contact and the machine won't run. The tolerances are thousandths of an inch in there.
Nov 21, 2011 | Hobart A200 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
MIXER WILL NOT RUN AFTER CLEAN/LUBE TEN YEAR SERVICE.
The speed control is a governor setup, it's purely on and off, as the weights on the motor shaft spin faster, they press against the contacts, and when they spin a fast enough speed, it turns off current to the motor, which makes it slow down, and current gets turned back on.  That way, you get a pretty consistent speed on a setting no matter whether it's lightly loaded or whipping something fairly heavy.  If you can turn the motor shaft by hand, then you don't have anything binding, but you might have gotten the speed control out of adjustment.  give it another go.
Sep 21, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Hobart A200 Stand Mixer Logo
2,288 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
