Question about Brother FAX-575 Plain Paper Thermal
Fax keeps screaming when answering machine comes on -
Tried solutions listed, they don't address this machine. How do I keep the fax machine ready to recieve and take incoming calls on my answering machine? I'm not using the answering machine feature of the Brother fax 575. I don't have a manual - lost it. Now what?
    Genius:
  • 3,422 Answers
you can download the manual from here..
im further looking to ur solution of ur problem
Goodluck,
please dont forget to rate me as fixya..
Posted on Jan 30, 2008
    Sniper:
  • 112 Answers
Here is a link to the manual for your fax
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_FAX_575_EN_75.PDF
Hope this helps!!!
  • Uplate Jan 30, 2008
    you would need to set your fax to TAD: Answering Device...
    Use this mode when your faxline is connected to an external answering machine...
    your answering machine will automaticly answer every call...voice messages will be stored on the external TAD (answering device), and faxes are printed
    Ring delay and ring F/T do not work with this setting
The answering machine and the fax come on at the same time when someone is calling in - therefore they cannot leave a message due to all the squealing
I don't see a specific question being asked, but I assume you want to know how to be able to stop the answering machine and the fax machine from answering calls @ the same time.
The easiest solution would be to order another telephone line and use it for the fax machine.
The only other option would be to purchase a device that "listens" for the polling beep that fax machines make and, if it hears it, sends the call to the fax. If it doesn't hear it, the call is sent to the answering machine.
Here is an example:
http://www.usr.com/products/telephony/telephony-product.asp?sku=USR4000
Apr 09, 2011 | AT&T ATT1739 Digital Answering Machine
I HAVE TRIED TO FAX BUT I KEEP GETTING ERROR 344 THE FIRST PAGE GO THROUGH AND THEN IT TELLS ME FAX FAILED I'VE TRIED 5 TIMES THE RECIPIENT SAY THE FAX IS READY TO RECIEVE
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted or:
The remote user has pressed the Stop key while the reception was in progress or:
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the fax session was using error correction, disable ECM if not already.
Mar 24, 2011 | HP Office Equipment & Supplies
Keep receiving duplicate faxes
Some Brother fax machines are programmed incorrectly so they do not acknowledge receiving the last page of a document. The sender doesn't know you got it, and will resend.
It's harsh advice, but the only solution is to buy a different brand.
May 07, 2010 | Brother IntelliFAX 4100 Laser Fax
Not receiving faxes. Machine just keeps ringing.
Make sure fax is not set to TEL mode...it will keep ringing and never answer. It should be set to FAX. mode.
Mar 15, 2010 | Office Equipment & Supplies
Fax Machine vs. Answering Machine
If you are there unplug the phone line from the answering machine. -Carl
Jul 24, 2009 | Brother FAX-575 Plain Paper Thermal
Code 721 keep coming up and the machine keeps beeping. How do we fix it?
Error 721: Cannot connect to the Pop Server. (Incorrect POP Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the Network Administrator
Were you setting up email by chance, you need to make sure the email server settings are set correctly for your POP email provider. Otherwise you will get this message. If you don't use email, go into settings (Fax Parameters) and disable email features.
Apr 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Incoming faxes are showing busy on the sender's end.
TAM is the setting for answering machine. Set it to fax. Not sure how on those ones.
Mar 31, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Changed cartridge on fax and keeps saying install new cartridge will not let us do anything else
sir,
can u send the fax machine model number so that i can forward any solution for that.my mail address is tulasi143007@yahoo.com
Sep 29, 2008 | Samsung Office Equipment & Supplies
Brother Multi function centre with fax, MFC 885CW we have the setting on F/T, it answers a fax after 2 rings, if a call coming in it keeps ringing, but on callers end it keeps beeping fax noises, callers...
I had the same problem using my Brother MFC 8460N fax on the same line as my regular telephone, which has an answering machine.
There was nothing wrong with my equipment. It was a set-up issue. I solved it as follows, and maybe this will be helpful to you:
Here's what I did, step by step:
1. Put your MFC and your telephone near each other, and within reach of a phone wall jack.
2. Go to the fax machine. Take the telephone line with the clip on the end of it that comes out of the fax machine. Put that into the telephone wall jack.
3. Go to the answering machine. Take its telephone line with the clip on the end of it and put that into the BACK OF THE FAX MACHINE. The port on the back of my fax machine says something like EXT TAD which means external telephone answering device.
4. Go back to the fax machine. You'll now need to play around with the menu options for the fax. My Brother MFC shows this stuff in a little screen on the front. Try and find the Fax Setup options. Next, try and find the Fax Receive options. If you do, select something like External TAD fax receive mode. Do not give up, you're almost done.
5. Next, set ring numbers on both devices, the fax machine and the answering machine. I set both devices' ring numbers to 4. I don't know if these are the optimal settings, or what happens if you set them at different ring numbers. I only know that a "4 and 4" setting works for me, and am not inclined to mess with it.
6. Final detail: the setup should be transparent to a voice caller. Someone who is sending a fax, though, might be a little confused IF, like me, they lean over to listen to their fax machine dial and screech, just to be sure it's working. Such a person may faintly hear my outgoing answering machine message before they heard my fax machine's screech kick in. They might think that they had a wrong number, cancel the fax, try again, call me with questions, etc., etc. So I changed my outgoing message to something like: 'You have reached xxx xxx xxxx. To leave a voice msg, please wait for the tone. To send a fax, please continue the transmission and it will be printed. Thank you!'
That's it. Hope this was helpful.
Best,
Wilbere
Check out my listings on http://stores.ebay.com/WILBERE
Aug 07, 2008 | Brother Office Equipment & Supplies
Brother FAX-575 Plain Paper Thermal Logo
101 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
