Question about Akai PT46DL10 46" HDTV-Ready Television
Flashing I've replaced the bulb and the tv seemed to be working fine, its now 3 weeks later and in the center of the screen there is a white flashing, it almost looks like a dvd skipping. any idea's on what this could be?
  • 1 more comment
  • mjohnny Feb 15, 2008
    i have same problem
  • Phatai Mar 12, 2008
    But it does it spuradically (sp) sometimes it will go an hour then start doing it, and other times it will do it right off the hop. I've had about my wits end with this thing but i can't afford to go out and get another big screen.
  • tlshowe May 21, 2008
    got the same flashing problem...does it within 10 minutes of turning the TV on and sometimes starts flashing immediately after turning the set on...what gives...any ideas...thanks
    Problem Solver:
  • 15 Answers
Is it like a line about 2 feet long and aboout 2 millimeters in hight, only happens on contrasts of dark to light? got the same problem then if it is (if you hook it up to the PC input it actaully goes away though!!) makes a beautiful pc monitor/dvd player.. Also doesnt happen on widescreen movies!
Posted on Jul 01, 2009
    Problem Solver:
It could be a bad connection on the back with the cable try to tighten them up.
Posted on Mar 09, 2008
I have a samsung dlp 61 inch tv...older model...just replaced the lamp but the temp light remained lit....then two weeks later the tv will only turn on after several attempts and ever since it has been off...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 2001 sony 53' rear projection tv model #KP-53HS30. It seems has a wavy section on the upper left hand corner and lower right hand corner of the screen. All the bulbs are working fine but seems...
Try this. The follow was found on tv-forums dot com by Zyntar...
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Oct 20, 2010 | Sony KP-53HS30 53" Rear Projection...
TV wont stay on.
Similar problem with my Sony. unplug for 36 hours and try again
Aug 13, 2009 | Samsung HL-R6767W Replacement Lamp
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
No picture on Samsung HLN5065W
sounds like the color wheel has gone bad..the part is not very expensive but it takes some work to replace it
Nov 29, 2007 | Samsung HLN5065W 50" Rear Projection...
Akai PT46DL10 46" HDTV-Ready Television Logo
134 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
