Question about GE JVM1440 Microwave Oven
Noisey turntable My 3 yr old GE over the range micro wave has developed a bumping noise on the turntable as if it was off the tract.I have removed the turntable and the track it revolves on several times and made sure it was rotating correctly.Everything looks normal,wheels on track looks good,no chips on turntable or anything. Anyone had this problem?? i have had several GE's in other homes with no problems........
  • bojeepers Jan 30, 2008
    thanks,i checked the gear and is good.....microwave is quiet when the turntable is removed and operating .turntable motor is quiet and smooth. I am now suspecting the plastic carrier with the 3 plastic wheels is the problem.By removing the gear and placing the turntable on the carrier and spin it by hand it makes the same noise.Thanks  for the help.....Bo
  • Anonymous Feb 19, 2008
    Turntable not only noisy; wheels have damaged the oven floor. White
    finish all gone under wheels. Showing ugly brown. I wonder if it is still safe to operate the oven in this condition.
    Any answers?
    President:
  • 1,314 Answers
Try pulling on the plastic drive and inspect it you just pull up on it to remove it
Posted on Jan 30, 2008
  • robert samples Jan 30, 2008
    well your more than welcome i think your right
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Micro wave GE space maker 1800 is heating food well but with noise and turntable not moving,,what could be the problem?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My 2 yr old GE profile micro is not heating !! lights, turntable all on but no heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Apr 17, 2010 | Maytag MMV5186A Microwave Oven
Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
Microwave stopped working
to indutolia
The original problem was probably a bad turntable motor, which is pretty easy to replace.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Gear that rurns turntable very noisey
it may be the fan/fan cover assembly or it may also be the magnatron, after a while of use, before faulting the plates inside dislodge and can rattle around while in use.
Nov 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wave will not heat products. All other systems are functional.
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 08, 2008 | GE Microwave Ovens
GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE JVM1650 1000 Watts Microwave Oven
Ge jvm1860 microwave oven
Could the noise you are hearing be maybe an electical sparking/arcing noise? It could be that the wave guide cover inside the micromave cavity is dirty, and needs to be cleaned. If it is not, then it could be a bad magnetron crackling and going bad. If this is the case, it is likely going to damage the waveguide and render the microwave unrepairable. I wouldn't use it until you have it checked out or take it apart and check it out yourself. Hope this helps.
Oct 17, 2006 | GE JVM1860 Microwave Oven
GE JVM1440 Microwave Oven Logo
143 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
