Question about Wahl 9765-301
Wahl 9765-301 when cutting my dogs hair the clipper seems to stall and stop cutting .it has worked well for 3 yrs . i just replaced the blades . please help i cant figure this one out
  • Anonymous Jun 01, 2008
    blades not cutting well, pet hair gets between blades, and binding sound is heard. I have removed the blades, oiled and realigned according to instructions on internet.
  • 3 Answers
Sounds like you have very dull blades and need to replace or sharpen them also your blades may not be tight enough or your screws may be stripped enough as to not tighten down properly. does your clipper sound like the motor wants to slow down when you try using them for an extended time? if so replace the clippers. did you take apart the clipper housing and make sure it is free from all hair? sometimes hair will get into the motor area and cause the blades not to work properly.
Posted on Oct 14, 2008
  • 2,039 Answers
If you put oil on the blades does it help if you remove the blade you should see the pivot what make the blades moves hair preventthe blades from moving freely after if it still weak motor is weak not mush to do with that pricewise better by andnother one cheers
Posted on Jan 30, 2008
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
How do you adjust the head to cut various thickness of your dogs hair?
RTM. Read the manual. You're probably not using the correct blade and size.
Aug 06, 2014 | Wahl Animal Clipper Pcmc-2 Dog Cat Horse...
Clippers not cutting
It is not unknown for a sharpen to be no good, anyone can turn out a bad sharpen. Look for correct blade assembly, check that there is sufficient pressure holding the blades together, check there is no missing stroke. Check the blade is secure and not wobbling. If the above are OK I would buy a new blade. You could also return the blade with the clipper for the sharpener to test for themselves.
Nov 20, 2013 | Wahl BravMini Rechargeable Trimmer Purple
My clippers are pulling the dog hair instead of cutting, why?
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Nov 24, 2012 | Wahl KM2 Speed Electric Clipper: Two Speed...
My 78950-100 will not cut my dogs hair
The clipper that you purchase dose not have the power to cut the Dog fur, You need a Andis Xcel 2 speed with a # 10 clipper blade. www.mannyssharpening.com this clipper is quiet and has power. askmannyssharpening@yahoo.com
Feb 04, 2010 | Oster 78950-100
My hair cutting device is making the noise that it should but the blades arent moving so they are not cutting any hair
On the side of the clipper their is a slot move this with a screw driver until the noise stops, the blades should start moving
Oct 11, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Mar 17, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Jun 24, 2008 | Wahl The Peanut Hair Trimmer
Wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
Oct 04, 2007 | Health & Beauty
Wahl 9765-301 Logo
694 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
