Question about Akai LCT3215/26 32 in. LCD Television
Turn off /turn on
I have an akia 32 inch that turns on and off by itself every few minutes none of the other buttons register when on is this a fuse problem oris the switch broken
  • mslopez2008 Jun 18, 2008
    i turn it on and it turn off
  • kwangulianna Feb 24, 2009
    when I turn on TV . TV turn off by itself
I have an 32 inch Akai TV/DVD Combo; the TV turns off by itself about every 20-30 min, and when I put in DVD to play, the TV cuts off.
Posted on Oct 05, 2008
After running for a few minutes the picture abruptly shuts off and turns back on for a few minutes then shuts off. This cycle repeats itself over and over.
Make sure the top and back of it are not dirty or obstructed, it sounds like it is overheating and shutting down to protect itself. Or your main power board is going out.
Nov 29, 2015 | Sceptre 32 X320BVHD 32 LCD TV
My rca tv when i turn it on it goes off by itself in a few minutes
Check and replace damaged component/s in the main power supply regulator section circuit.
Sep 07, 2012 | RCA 32F531T 32" TV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My 50 Viore dlp tv turns itself off after just a
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
Jul 20, 2009 | Televison & Video
Akia 32 inch lcd turn on then shuts down, the only way to get it to power up is to disconnect power cable, let set for 20 to 40 seconds, reconnect power cable and then it will power up with no probelms....
In about 95% of the time when the TV is having a hard time turning ON or turns OFF by itself or needs to be unplug to make it work again; those are symptoms of dying or defective power supplies.
I repair these power supplies, if you need further info write to jah2mil@hotmail.com
Dec 12, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Lcd 32 inch akia
The possible solutions at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply. The other problem could be a defective back light inverter board but you would need to measure the 24VDC that powers up that board, if the voltage is lower then 20VDC or is missing; then your power supply is defective.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai LCT3285TA 32 in. LCD Television
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
Akia 27 inch tv wont turn on
I WILL NOT BY AKIA TVS no more thay **** cant get parts
Apr 01, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Televison & Video Logo
354 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
