Question about Kitchen Ranges
Starter on range top frigidaire
No spark when u turn on any of the burners
  • prozzo Oct 07, 2008
    I get clicking with no spark. I can see that it looks like the ceramic/metal probe in the burner is deteriorated. Can I replace it? It looks like 2 diamond screws to disassemble.
    It's a Whirlpool
    President:
  • 1,314 Answers
You need to replace the spark control module most are little blue boxes under a panel on back
Posted on Jan 30, 2008
None of my stove top burners will spark to ignite
There is an ignition module that sparks when it calls for lighting. This module could have a loose connection or be dead.
Apr 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Electric spark starter on one of the burner runs continuously
check the spark head on that particular burner first for dirt,they all need to be clean to recognize the flame after ignition and sense the flame to shut off the sparker module after ignition,and if not you will need to replace the spark module that fires the sparkers itself,but try cleaning sparkers and underneath where the wires connect to the sparkers first for contamination,its cheaper than starting to replace parts
Dec 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignitor on Frigidaire model PLCS389DCC is not working. How can I replace it.
There are a couple of ways you can resolve this issue, depending on what isn't working. As it's difficult to determine by the brief description of the problem you're having, I can't tell if the main spark (ignitor) module is the faulty component, or if you need to replace a specific ignitor/orrifice assembly for one or more burners.
If none of the top surface burners are lighting when you turn them on, it is most likely the spark module that needs to be replaced. If it's only one burner that is not lighting, then you'll need to replace that burner's ignitor/orrifice assembly.
To get at these components, all you need to do is lift up the top range surface to expose the burner assemblies and the spark module. Be sure to turn off the gas line and unplug the range from the electric outlet to prevent any shock hazard, etc. Removal and replacement can be done with simple hand tools and by simply unplugging the electrical plug on the spark module.
Here's a exploded line drawing showing the components, part numbers, and a price list as well. You can order the part(s) needed online as well.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PLCS389DCC&productCategoryId=0122008&brandId=1428&modelName=DUAL-FUEL-RANGE&diagramPageId=00002&componentDescription=BURNER&documentId=R0504191&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Rebuilding old wolf stove
It is possible but you have to know how, top burners will be easier to do then oven, for top burner you will needed push button switch, spark module and electrodes. I never done the oven but it is possible. Have fun.
Jan 03, 2009 | Frigidaire FGF378AC Gas Kitchen Range
CONSTANTLY SPARKING
ONCE BURNERS HAVE LITE TURN THE BURNER KNOB BACK THE OPPOSITE WAY A LITTLE BIT AND SEE IF THR IGNITER QUITS SPARKING, HOPE THIS HELPS.
Oct 22, 2008 | Frigidaire FGF316 Gas Kitchen Range
Gas ignitors do not shut off
Are you saying the spark module is constantly sparking? If so, you may have one of your surface burner switches shorted, causing the spark module to stay on. Or, you could have a ground in your wiring harness to the spark module. Here's a way to check: 1. Unplug range, or turn off circuit breaker. 2. Locate your spark module. It's usually located in the back of the oven cavity, or behind the rear panel. There should be a wire going from the spark module to each burner switch. Carefully disconnect each burner switch one at a time and re-energize your range to see if the problem goes away. If the problem doesn't go away, turn the range back off, reconnect the switch and move to the next switch wire. 3. If you disconnect each switch and the problem persists, then I would suspect an internal short in the spark module, or a ground in your wiring somewhere. There should be a tech sheet with diagrams located somewhere on the back of the range to assist you. I hope this helps.
Jul 28, 2007 | Frigidaire FGF316 Gas Kitchen Range
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
