Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you add staples to a DI251? - Canon CLC 5100 Copier
Anonymous
Level 3:
  • Master 1,110 Answers
  • Posted on Dec 30, 2009
Anonymous
Master
Level 3:
Answers
1110
Questions
Helped
544606
Points
4088
Depends on what model of finisher you have. There were 3 different finishers available for the Di251. There are usually instructions inside the stapler cover "door" but they may not help much. Also if you have OEM Minolta staples then there is an instruction sheet in the box. Really need the model of finisher before I can give you a better answer.
3answers
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
How to add staples to copier
Oper the finisher door. Pull out the staple cartridge holder and replace the new staple cartridge. Follow detailed instructions at the side panel door ..
Di251 driver
The best driver s you mite find for the Di251 is 95 or xp Di251 series is legacy Minolta now konicminolta try their web site but doubt you will find it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta Di251 All-In-One Printer windows 7 64bit print driver
SORRY Di251 is a Legacy Minolta machine. At best can only use windows 95 or Xp. Minolta is Now KonicaMinolta
How do you open swingline tot 50
Here's a video that shows how to open an older Swingline Tot stapler:
Vintage Swingline Tot Stapler Demonstrated
How do you put staples in
There is a thumb release lever that keeps the slide bar locked down. Take your thumb and push up ******* this plastic release and it should open so that you can add staples.
10helpful
2answers
How do you add staples to a swingline 8784x stapler
You need to remove the black cap at the back of the stapler, then use a screwdriver to press down on a lever inside the stapler. The stapler holder will pop out at the front, then pull it further out and load with staples. May be an easier way, but this what worked for me.
9helpful
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
4helpful
C0500 error in a minolta Di251
Does the lid over the toner bottle close properly?
I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ? or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
old marine
old marine
ZJ Limited
ZJ Limited
