Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Westinghouse LCM22w2 Monitor
The menu screen for the monitor keeps blinking on and off. We cant get it to stop. We have tried to turn it off and then back on and it still will not stop. I went on the westinghouse website, left a complaint for the support techs and no one has contacted me. Please HELP!
I'll buy it from you. I just need a non-cracked LCD from this monitor. It doesn't even need to turn on. You can e-mail me at rallis@gmail.com
Posted on Jul 18, 2008
My monitor won't come out of sleep mode
Try unplugging the power cord from the monitor for 10 seconds and plugging it back in.
Jan 31, 2018 | Westinghouse Computers & Internet
Menu keep on blinking
Disconnect the monitor from the computer. Then turn on the monitor, if the menu keeps on blinking then that means the screen is starting to go bad and the monitor needs to be replaced.
You can also hook up the monitor to another computer. If the blinking stops then that means its an issue with the video card in your original computer.
Feb 05, 2012 | Samsung Computers & Internet
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
Welcome Screen Blinking Gateway Monitor
I would suggest that you re-install the disc. that comes with the screen.
If that doesn't work, check to see that your video card is working correctly.
May 26, 2009 | Gateway FPD1975 19" LCD Monitor
Westinghouse 26" tv SK-26H730S HDMI screen blinks with Dell Comp.
try using the 27 pin monitor input instead the hdmi possibly has a frequency variance
Mar 01, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Westinghouse LCM22w2 monitor need cord to pc
You need either a standard VGA cable or a DVI cable, depending on the type of video card you have.
http://www.ctcco.com for professional hosting solutions
Jan 19, 2009 | Westinghouse LCM-22w2 Television
Can't find correct setting for westinghouse lcm22w2 monitor
I don't know if this actually will fix your problem, but all LCM 22w2's are plagued with the 'white screen of death' and eventual power shutoff, including garbage characters and faulty menu, video output, etc. Here's how I fixed it.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supplyboard. This is a common problem plaguing motherboards and LCDflatpanels that use capacitors from Taiwan. If you know how to solder,or know somebody that can, it's actually a pretty easy fix. Take outthe yellow circuit board on the inside, write down the specificationsfor each of the capacitors (the cylindrical things) go to theelectronics supply store and get the replacement capacitors. You can goover the voltage specification (not under), but keep the capacitancevalue matching. Replace one at a time. Go to www.badcaps.net foradvice, tutorials and training on doing this. *You really shouldreplace all the capacitors*, but the very large one next to the powerplug I did leave on the board because I couldn't find a match. To mydelight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
Jan 07, 2009 | Westinghouse LCM-22w2 Television
Westinghouse L1916HW Monitor On-Screen Display keys malfunction
Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms Widescreen Monitor and it turns itself off . Sometimes it works without problem for long time or just for 15 mins, and after turn on it several times the problem disappears. Now,when it is working without the problem, sometimes the volume menu appear on the screen without touch the monitor and if you try to close it, appear again.. I am using it with Windows 7. I need help. Now, I have a router wireless close to it, Can it affect the monitor?
Dec 14, 2008 | Computers & Internet
Monitor will not turn off and keeps flashing the words Auto processing
it is not a bad rom. if it was a rom it would constantly act up but it only acts up upon overheating. The solution is difficult but if you open the monitor you can find all of the heatsinks take them of and replace them with bigger ones. or have a fan blowing on it at all time it is active i added bigger heatsinks to my emachine le1799 and it solved this problem of pulling up menu and changing setting by itself and the lack of the ability to turn power of.
Sep 15, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
122 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
