Question about Maytag MAH8700A Front Load Washer
No power at all
We have a two year old Maytag MAH8700A Front Load washing machine. It started fine and then there was a poof noise and now it has no power. The partially wet clothes are locked in. What is the problem?
    President:
  • 1,314 Answers
Ok first if you look in the dispenser drawer may have to push the tab and remove the drawer there is like a yellow pull tab will unlock the door second if your sure their is power to the washer the look at the control panel for burned resistor on the control bd and let me know if your serial number ends in ga through gx or ja through jn
Posted on Jan 30, 2008
My Maytag Neptune Front load washer walks in the spin cycle (MAH8700A*
I had this problem solved by changing this control board:
Whirlpool Part Number 34001494: CNTRL-ELEC I bought this from AMAZON for under $ 200, was able to change myself, good luck
May 26, 2014 | Maytag MAH8700A Front Load Washer
Drum does not spin centered, it is rubbing the seal
This isn't good. it's normally related to the tub bearing or spider brace on the inner/ outer tub. Both parts tend to be very costly. If its under a year old you will be covered in warranty.. if not it maybe time for a new machine. I have seen this on washer's as little as 14 month old. I'm not a front load washer fan because of this problem.
Jan 19, 2014 | Maytag MAH8700A Front Load Washer
Washer vibrates and walk in excess
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 31, 2010 | Maytag MAH8700A Front Load Washer
Won't drain or spin and makes a noise in drain pump
you probably have a coin stuck in the water pump...i had the same thing happen to me last year...5 min fix...cost me $75 service call...i know better now...easy fix ...
Aug 30, 2010 | Maytag MAH8700A Front Load Washer
Washer will not spin and makes a noise when you spin it by hand.
1st check if the belt has fallen off, next the noise is this bad could be bearing trouble...
Apr 20, 2010 | Maytag MAH8700A Front Load Washer
MAH8700A Error code 2E What does this mean?
According to the trouble shooting manual that came with my Maytag MAH8700A, code 2E refers to "Voltage for motor control bus is under specified limit." It states that the action to be taken is to "replace motor control board."
Nov 04, 2008 | Maytag MAH8700A Front Load Washer
Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
Jan 23, 2008 | Maytag MAH8700A Front Load Washer
Maytag MAH8700A
Joe, ds is a door lock malfunction. The door lock latch shows closed and the door switch shows open. Try this, unplug the unit for 60 seconds and see if the error comes back. If it does, with the power on press and hold the chime and xtra rinse pads together for 3 seconds. This will put it into the service mode. Once in the service mode press the chime button again to unlock and the temperature pad to lock. See if they operate. If still no luck you are going to have to do some tests on the door lock switch to see whats happening. You do have a 2 year warranty on these parts and being that it is only a year old, tell them to throw in the labor....Catriver...post back.
Dec 13, 2006 | Maytag MAH8700A Front Load Washer
Maytag MAH8700A Front Load Washer Logo
88 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
