Question about Thermador SC302T Electric Double Oven
Thermador Convection Oven
I purchased a used (2007) Thermador Double Convection Oven. I installed the oven and only the lower oven works. I pulled it out to check wiring but everything looks ok. Any advice that you might offer?
    President:
  • 1,314 Answers
Well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
What does E 2 on a thermador convection thermal double oven mean
depending on the model, could be run away cook/clean temps.
Oct 15, 2012 | Thermador Ovens
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
I have a Thermador double convection oven, that I'm getting a f54 code plus a lockout indicator readout at times. Whats that all about.
because you used self cleaner funtions that burn will cause machine over heat try to remove the oven and check the thermo limit in the back of the oven
Jan 12, 2010 | Thermador SMW272 Electric Double Oven
The lower door does not close firmly. It seems like the spring load is weak. Is there a way to improve the spring tension? I have model CM302ZS (Microwave/convection oven on top and convection oven on...
There is no provision made for adjustment of springs,
I'm afraid the only solution is to replace both door springs.
Trust this helps solve your priblem.
Dec 21, 2009 | Thermador SC302T Electric Double Oven
The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Nov 27, 2009 | Thermador SC302T Electric Double Oven
I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Feb 19, 2009 | Thermador C272 Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
602 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
