Question about Sony FD Trinitron WEGA KV-36FV300 36" TV
SONY TV Model KV-36FV300 Problems
We have a SONY WEGA TV KV-36FV300, about 6 years old. It powers on and off on its own. Is this repairable?
    Problem Solver:
  • 9 Answers
Plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Posted on Jul 29, 2009
Vrya
  • 62 Answers
SOURCE: SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Posted on Feb 19, 2008
  • 4234 Answers
SOURCE: SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Posted on Oct 01, 2008
SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Posted on Dec 01, 2008
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Posted on Feb 06, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
My Sony WEGA kv-32" TV
The "D" board is the main circuit board assembly containing most of the set's power and deflection circuitry. It's the board that typically causes most of the problems because there's so much on it. Unfortunately, this board is no longer available from Sony as a part, and must be repaired to the component level. Many shops don't want to (or can't) get into that depth of repair, so they quote a high price on board replacement. There is no single part you could order to repair this board yourself, I'm afraid. There are some companies in the business of repairing boards, but you're still looking at $200 to $300. With the price of a 32-inch LCD set now around $300 to $400, there's no point in trying to fix a TV when it's just a few dollars more for replacement.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
May 04, 2010 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Power light is blinking TV does not turn on
the power is blinking because there is a deffective parts... the supply that makes oscillation of tv has been cut off... either the horizontal transistor is open or the resistor from the abl change its value...if you have knowledge with the parts maybe you can try... only the qualified servicemen can repair the problems...
Aug 29, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No signal
Check is RF Antena/ Cable connected? If yes, go to TV Menu and select Auto-Program. TV will start tuning and search all available channels on cable/ on-air. If there is no channel reception, TV has defective Tuner. If you know basic electronics knowledge, replace the Tuner or contact nearest Sony repair shop.
Jun 04, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Blank screen
These tvs are known for bad power supply capacitors. Try power cycling the tv several times (8-10) to see if it finally comes up. Four flashes indicates a power supply problem or a deflection problem, usually it is the first. Take the set into a shop if you are not an electronics technician, as these are dangerous areas to work on. Otherwise, use a capacitor checker to test the caps, starting with the main supply caps which are usually 200v. I've found these to be low by 200uf. Also, check the 1000uf and 2200 uf caps. These will be low by 100 - 200uf.
It could be a flyback or deflection problem, but check those caps first.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony 36fg-36fv300
plug tv directly into the wall and not through the cable box.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony Trinitron TV will not turn on
First thing that comes to mind is that the horizontal driver transformer has bad solder connections on the primary and the secondary windings. Also a set this old could also have a defective regulator IC if you dont know wht m saying , b=est thing to do is find out how much an estimate is then go back to best buy and see what a new set cost cause man you got your moneys worth outa this one for sure!!!!! Good Luck
May 02, 2006 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony FD Trinitron WEGA KV-36FV300 36" TV Logo
316 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
