Question about Ovens
Whirlpool oven model sf315peew Super cap 465
Evening,
This is a gas stove/oven. The oven will not heat at all. The clock is on and the heat cycle will count down but no heat. I had to reset the fuse for the circuit the oven is on in the kitchen ( may or may not be part of the problem). The stove top still lites. Any suggestions?
  • 2 more comments
  • kanooterjp Jan 30, 2008
    Tech17,
    Thanks for the info, but, the oven/broiler burner are one in the same. I tried to lite the broiler to no avail. Is it still the ignighter?
    Tech,
    I pulled the floor of the oven off along with the flame deflector. There is no burner tube in the top of the oven only one on the bottom of the oven cavity. I ohmed out the ignighter and it is open. I did a voltage ck of the lead leading to the ignighter and it was 120v. Am I correct to assume that the ignighter is bad?
    Tech17,
    I got the oven fixed. it was the ignighter. Thanks for the help!!!
    Saved me a $100 bucks.
  • Anonymous Oct 28, 2008
    I also have a sf315 peew super cap 465. The oven and broiler do not light. I am assuming it is the igniter?
I am having this same issue with the same model. If it were the ignitor, would you smell gas? I do not smell gas when the oven is turned on, therefore, I was thinking it was the regulator.
Posted on Oct 06, 2009
    President:
  • 1,314 Answers
Try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
Posted on Jan 30, 2008
  • robert samples Jan 30, 2008
    look in the oven do you see a burner tube up top with an ignighter on it
    yep there is no broil element thats why it didnt light lol
Whirlpool super capacity 465 stove
If you have an element that stays energized with the power off if it's 208/240 the heat relay on the control board is fused if 120 could be a board again or grounded
Jan 30, 2014 | Ovens
I have a whirlpool 465 super capacity stove. the top burners seem to have a mind of their own. 1 in the back doesnt come on at all and the other go to high heat even if i set them on low settings
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
Apr 21, 2011 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
Whirlpool super capacity 465 cracked ceramic element
You are looking at approx. $450.
Jan 01, 2010 | Ovens
My whirlpool super capicity 465 does not heat when bake button is pressed. the broiler and stove top both work.
Your bake element is probably out. No biggie! We sell parts and will be happy to help you with this. Just call us with your model number. Hope this helps! Ella
Aug 18, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
OVEN WON'T LIGHT AND HEAT, NO GAS SMELL
Hi!!! check your oven spark module its inside the oven it looks like this pisture..The module provides the spark to all ignitors..Good luck..
Jan 04, 2009 | GE JGRS14 Gas Single Oven
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
423 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
