Hello sweetiepie
All you need to do is remove the card and locate the protection switch. It is normally located on the left of the card and it is normally a little white plastic lever. Just move this lever to the other position and it should work just fine.
If this does not solve your problem , there is either a problem with the card or your camera. Contact me then and I will guide you further.
Kind Regards
Andrea
Check your memory card to ensure that there is no read-only switch on the edge of the card, and that it is not turned to read-only. That would stop the card from accepting further data being written to the card.
-a.
