Question about Pioneer DVR-530H-S DVD Player/HDD Recorder
Remote control I accidentally deactivated my remote control (selected remote 2 in the setup and saved without intending to do so). This has effectively rendered my remote control useless since it is set up as remote 1 and I can not use it to access set up so that I might change the setting. Help, I have no idea how to rectify this problem.
I called a Tech @ Panasonic and he told me to point and hold the "OK" button and the number 2 for about 10 seconds. Then I pressed the power button for the DVD recorder and it worked.
Posted on Mar 19, 2008
I accidentally activated dialogue below picture. how do i deactivate?
it is called closed captioning . look for that and turn it off in main menu or setup
Sep 06, 2015 | Televison & Video
Need a universal remote code
Try 0000..
If that doesnt work I have another solution for. Westinghouse flat panel TV
TV 10812 probably has the correct IRsignalsfor enter programmed to the ok/select button. However the comcast and access remotes are intended to control a cable system so even in tv mode the remote sends the digit, ch+1and enter signals to the set top box.
There are two ways to defeat this.
1)Turn off channel lock. Sethe 9xx comand for this.
OR2) Assign a EFC for the Enter signal to the device mode.
1) Press TV
2) PRESS SETUP UNTIL IT BLINKS TWICE.
3) Enter 994 (two blinks)
4) Tap setup(DO NOT HOLD)
5) Enter 00069
6) Press ok/select.
The remote should blink twice and the ok/select button should work in the tv mode.
Use 1 unlessyou're going to use remote with cable box.
I hope this works...
Dec 17, 2014 | Westinghouse Televison & Video
Change emerson tv input without remote
As there is no menu button at the front panel of this TV, there is no way to select its input selection, without a remote control. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 02, 2013 | Televison & Video
Zenith menu without remote
Without a remote control, you can't program it. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. For more information; check the links given below, and find which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability.
For more information, check these links.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Nov 14, 2013 | JVC AV-20220 TV
Have a satellite called Aura and also bought a remote control wich is called one for all and i cant find the code for satelitte and it works with the tv any clue ????
0038,0031,0037,0032 are the codes intended to work with most satellites. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 16, 2013 | Televison & Video
I have an RCA 27v512t without the remote.How do I change it to aux so I can watch DVDs?
Without remote control, you can't select its inputs. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
I would like to know the code for my dvd player its a RCA please
Hello
Setup code for RCA with Philips SRP2003/27 is:
2351
[1] Make sure the receiving device is able to
respond. E.g. when you try to repair the Play
key for your DVD player, make sure to insert
a DVD into the DVD player otherwise the
Play key is not able to function.
[2] Select the device
that you wish to
operate (e.g. DVD).
Press the (DVD) device
selection key to
select DVD.
[3] Keep keys (1 & 4) and
pressed
simultaneously for 5
seconds
The red Setup
light lights
up. The remote control is now in setup
mode.
8 EN
[4] Press and hold the key that does not
function and immediately release it when
the device responds.
* If the key still does not function as expected,
try pressing it again for a longer period of
time.
[5] Press the (DVD) device
selection key twice
to save your settings
and exit setup
mode.
When no key
is pressed for 5 minutes or more, the
remote control will exit setup mode,
automatically saving all your settings.
OK.
Aug 15, 2011 | Philips SRP2003/27 Remote Control
Received new DirecTV HR-21-100 PVR, tried to set up device in remote, now nothing works
Your DirecTV device is probably set on RF (Radio Frequency), which the Harmony can't use. You will need to set it to IR (Infrared) for the Logitech remote to control it.
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
May 20, 2010 | Logitech Harmony 670 LCD Remote Control
How do I undo a reformat on an HP? My HP was reformatted and I need to return it to the previous state. Already tried system restore, but prompt said there is no point to restore to. Is there a way to...
Troubleshooting
Accessing Computer Setup
The information and settings in Computer Setup are accessed
from the File, Security, Tools, and Advanced menus.
1. Open Computer Setup by turning on or restarting the
computer. Press f10 while the F10 = Based Setup message is
displayed in the lower-left corner of the screen.
To change the language, press f2.
To view navigation information, press f1.
To return to the Computer Setup menu, press esc.
2. Select the File, Security, Tools, or Advanced menu.
3. To exit Computer Setup, choose one of the following:
To exit without saving any changes, use the arrow keys to
select File > Ignore changes and exit, and then follow
the instructions on the screen.
To exit and save all the settings you have entered, use the
arrow keys to select File > Save changes and exit, and
then follow the instructions on the screen.
Your preferences are set when you exit Computer Setup and take
effect when the computer restarts.
Computer Setup Defaults
To return all settings in Computer Setup to the values that were
set at the factory:
2. Use the arrow keys to select File > Restore defaults.
3. Select the Restore Defaults check box.
2–2
Maintenance and Service Guide
Troubleshooting
4. To confirm the restoration, press f10.
5. Select File > Save changes and exit, and then follow the
When the computer restarts, the factory settings are restored, and
any identification information you have entered is saved.
Selecting from the File Menu
Table 2-1
File Menu
Select
To Do This
System Information ¦
View identification information about the
computer and any battery packs in the system.
View specification information about the
processor, memory and cache size, video
revision, keyboard controller version, and
system ROM.
Save to floppy Save system configuration settings to a diskette.
Restore to floppy Restore system configuration settings from a
diskette.
Restore defaults Replace configuration settings in Computer Setup
with factory default settings. (Identification
information is retained.)
Ignore changes and exit Cancel changes entered during the current
session. Then exit and restart the computer.
Save changes and exit Save changes entered during the current session.
Then exit and restart the computer. The changes
you save are in effect when the computer restarts.
2–3
Troubleshooting
Selecting from the Security Menu
Table 2-2
Security Menu
Select To Do This
Administrator password Enter, change, or delete an HP Administrator
password.
Power-on password Enter, change, or delete a power-on password.
Password options ¦
Enable/Disable stringent security.
Enable/Disable required password on restart.
DriveLock passwords Enable/disable DriveLock; change a DriveLock
user or master password.
DriveLock Settings are accessible only
when you enter Computer Setup by turning
on (not restarting) the computer.
Smart Card Security Enable/disable power-on support for smart cards.
This feature is supported by select smart
card readers only.
Embedded Security ¦
Enable/Disable the embedded security chip.
Restore embedded security chip to factory
settings.
Enable/Disable power-on authentication
support.
Enable/Disable automatic DriveLock.
Reset power-on authentication credential.
Embedded Security settings are accessible
only if the computer is equipped with an
Device security Enable/Disable devices in the system.
Enable NIC for inclusion in MultiBoot.
System IDs Enter user-defined identification values.
2–4 Maintenance and Service Guide
Troubleshooting
Selecting from the Tools Menu
Table 2-3
Tools Menu
Select To Do This
HDD Self Test options Run a quick or comprehensive self-test on any
hard drive in the system.
Battery Information View information about any battery packs in the
computer.
Jan 01, 2010 | HP Pavilion dv4000 Notebook
Looking for remote codes for vizio sound bar and comcast remote
I have a vizio universal remote and the code that works the vizio sound bar is the first one listed under audio/vizio 0660
Oct 16, 2009 | Televison & Video
Pioneer DVR-530H-S DVD Player/HDD Recorder Logo
236 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
