Question about D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
I just moved into an apartment that comes with the internet provided by Sudden Link Cable services through an ethernet port in my room. Apparently the port is wired to a main closet where i'm connected to a DI-604 router.
I wanted to connect my DI-524 to my ethernet port in my room so i can connect my pc and laptop (the laptop will be connected wirelessly).
Is there a way to connect these two routers together? If so, how? I know I shouldn't connect my cable to the WAN port on the DI-524 and should instead connect it to one of the LAN ports on the router. I'm not quite sure how to configure the settings within the DI-524 either. how do you set up the router and pc so that you can access the configuration window (192.168.0.1)? hellllp!!!
  • Anonymous Feb 16, 2008
    Same problem here
  • rtabulinar83 Sep 02, 2008
    I cannot connect my comuter on a network using DI-604.....but i can surf internet.
I wish to setup a second Belkin wireless router on home LAN to enable the TV to connect to the second router and be able to use internet services
Posted on Jun 11, 2009
    Problem Solver:
  • 16 Answers
Have a couple of questions...
Is there anything else connected to the DI-604 besides the incoming internet connection and the outgoing connection to your room?
If no, then why not just eliminate the DI-604 and install the DI-524 in its place?
If you wish to keep both rounters then you will have to make sure that they have different default IP addresses assigned to them.
If you have any further questions just send me a message...
Good luck
Posted on Jan 30, 2008
  • 12,061 Answers
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
How to setup tp-link TL-MR3220 on xp2002?
Connect the router's WAN port to your cable-modem.
Connect the computer to one of the LAN ports.
No other "setup" is needed.
Apr 29, 2014 | D-Link AirPlus DI-524 Wireless Router
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
My D-Link DI-524 will not reconize my IP address. What can I do? I reset the box and the lights continue to flash when they should have stop blinking.
remove all the cable conencted to your D-link except for the power cable of course ^_^ if the lights stops from blinking then possbile one or more of the ethernet ports on your router is malfunctioning try connecting the modem to your router by trying all the ethernet ports on the router until you see the lights stop from blinking if the lights stop blinking then that port is still usable on the router but in any case it also may be the routers settings you might need to set your router to the modems settings depending on your internet if it is DSL and you are using PPPOE there must be a user name and password that you need to input in the router for a calbe modem no need but since your situation is as we speak I do not think you have a cable modem for your internet, you might need to call your Internet service provider as well for further info for the user name and password the mdoem has unless you know how to get the user name and password from the modem ^_^ as far as I can go that's all
Jun 04, 2010 | D-Link AirPlus DI-524 Wireless Router
HOW DOES DL-524 WORKS AND WHAT ARE THE REQUIREMENTS FOR IT TO WORK?
First connect your cable from your interent service provider to d- link router .
Then configure your router settings .
For configure it you need to connect your router to computer with ethernet cable.
then access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then configure as your internet service provider setting.
Aug 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Help connecting Cable Internet through D-Link DI-514 Router
what may be happening is the wireless pc as it was; needs the dns and ip address flushing, also the pc you connected the router to as you must have conflicting ip addreses Click start run then type ipconfig /flushdns. You should ensure that the router is set to enable DHCP to assign ip addreses and make sure your'e network cards on all pc's are set to obtain ip address automaticaly in the TCP/IP properties. Restart the pcs and type 192.168.0.1 in your web browser and get into your router setings and check in the DHCP section that all pc's have been given an ip address. If all fails you may need to reset the router
Sep 03, 2007 | D-Link DI 514 Wireless Router (DI-514)
Connecting 2 computer thru DI-514
Well I believe wat ya need to do is simply obtain a NEW "Account" with NEW Logon & Password with a NEW Internet Service Provider. Then you set up the modem to connect to the new ISP, at the NEW ISP's address, with the NEW Password & Logon. When you got the modem ya should have got a "Setup" CD that should walk ya thru the connection routine... Below is a link for a "Users Manual" that should help you get connected. ftp://ftp.dlink.de/di/di-514/documentation/DI-514_qig_en_Quick-Install.pdf
Aug 15, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link AirPlus DI-524 Wireless Router Logo
500 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
