Question about Braun Syncro 7680 Electric Shaver
Part fell out of cleaner base
A small rubber (looks like a pencil eraser) fell from the base of my Braun 7680 cleaner .... not sure where to replace it. Cleaner working but sounds like something wrong. How can I find a full schematic to review the parts, etc. ?
Tks, James
It's probably one of the support rubbers that holds the shaver in place, and keeps it from falling too low into the cleaner. It's probably broken, but maybe you could put it back in place. There are two of those rubbers in the cleaner on the side where the trimmer is faced. If they both are broken, the shaver will fall too low, and the electric contacts on the top will also not fit - no charging as a result. My Braun service rep. said that the whole cleaning unit will have to be replaced to fix this. My plan, however, is to try with some small screws before I throw the whole thing in the "broken parts basket"....
Posted on Oct 23, 2008
Excessive vibration with Braun razor
Most likely, the oscillator in the drive unit is broken. You will find this part for model 7680 at shaversource.com. See link below for product and helpful disassembly video
http://shaversource.com/shaver-replacement-parts/braun-7000-series-syncro-motor-drive-unit-p-110.html
Jun 09, 2011 | Braun Syncro 7680 Electric Shaver
My 7680 clean and charge unit does not work
If it simply does not work at all, the circuit board is probably damaged. This is not repairable and you will need to buy a replacement. You will find a new clean and charge base at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Oct 22, 2010 | Braun Health & Beauty
Where to get and how to replace the shaver switch on 7680?
The switch is part of the outer case and can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-body-housing-select-models-p-811.html
To replace, you will need to gently pry off the cap that surrounds the cord hle on the bottom. Once removed, the side grips will pull away easily revealing 4 screws on the back. Remove screws to take the bask of case off and then lift out the 'guts'. Reassemble in reverse order
Sep 30, 2010 | Braun Syncro 7680 Electric Shaver
The red cartridge light is blinking on my dock. What does this mean? A while ago, the dock fell over and all the cleaner liquid fell out, so maybe I just need a replacement for the cleaner liquid. If so,...
Re the light:
When the «cartridge» light starts flashing, the remaining fluid in the cartridge is sufficient for approximately 5 more cleaning cycles. After these 5 cycles, the cleaning performance will be reduced and the cartridge has to be replaced.
When the «cartridge» light illuminates constantly, the cleaning function is locked and a new cartridge has to be installed.
Only then, the next cleaning cycle can be started.
To find a replacement, Refer to http://braun.com/ to find the website for your country.
Otherwise, refer to http://braun.com/us/consumer-service.html which will help you locate a local Service Center.
Mode number for the cartridge is CCR2
May 26, 2010 | Braun Syncro 7680 Electric Shaver
I have lost my instruction and cleaning manual for Braun electric shaver #7680 and need to find replacement.
Here are the instructions for a #7680 Shaver. http://www.service.braun.com/line/SH/S5491/S5491_9_NA.pdf
Apr 26, 2009 | Braun Syncro 7680 Electric Shaver
I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Jul 07, 2008 | Braun Syncro 7526 Electric Shaver
Top housing for the charging stand for a Braun Syncro 7680 Electric Shaver
I just experienced the same problem and came up with this solution. Use a spring clamp to keep the top of the charging stand in place. It works like a charm.
May 28, 2008 | Braun Syncro 7680 Electric Shaver
Braun Syncro 7680 Electric Shaver Logo
157 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
